Introduction: Home Made Maple Butter - Beurre D'érable Maison
Here in Québec, we call it "beurre d'érable" witch traduce to Maple butter. It does not have anything to do with "milk" butter, it does not replace butter in any recipes. It's more like cake icing. And it is simply delicious. I spread it on my toasts, use it on deserts or simply eat it with a spoon.
The only ingredient you need is pure maple syrup, so it's important you find good tasting maple syrup, witch is not easy to do, even here.
It is really simple to make. Cooking the syrup 13 degrees over boiling point and then mixing it until you get the right texture.
Tools :
Candy thermometer
Saucepan
Pastry brush
Handheld electric mixer
Glass of water
Spoon
Empty jars
Oven
Ingredient :
Pure maple syrup (about 2 cups)
Tools :
Candy thermometer
Saucepan
Pastry brush
Glass of water
Spoon
Empty jars
Oven
Ingredient :
Step 1: Calibrating Your Thermometer
Since you have to cook the maple syrup to 13 degrees (Celsius) over the boiling point, you first need to see at what temperature your thermometer tells you that the water is boiling. Anyway, just boil water, put your thermometer in the boiling water and remember what temperature it indicates.
Mine, today, told me just under the 100 line.
Ok, all this would make much more sens if my temperature grid was more precise... But anyway, I'll stop cooking the syrup a little under what would be the 113 degrees line...
If you stop it to soon, it will work, but not as well, you might get a butter that will "split" more easily and won't be as much homogeneous.
So precision will get you best result every time, but as you can see, it can work whit out precision tools.
Step 2: Cooking Syrup
So, have your brush and the glass of cold water ready.
Put about 2 cups (1 can) of maple syrup in your saucepan and start heating it at medium-high temperature. Watch it closely as the syrup will get foamy when it starts boiling, and it can get out of control and spill everywhere. You don't want that. It's sticky.
When it get foamy, use your brush to put water on the sides of the pan to stop the foam from going up. If it's not working, lower the temperature to medium or remove your pan to stop the panic.
Watch the thermometer, it will start boiling around 100 (...) and remember, you want to stop it at 113... (refer to step 1 if it's not clear enough)
When it's at 113, stop the fire, your done cooking the syrup.
Now have a break for 3 hours. Let it sit in the fridge (or overnight on the counter). The texture will get "more solid" (?).
Step 3: Mixing
Now is the tricky part.
It is not as tricky if you have eaten maple butter before, as you will know what texture you want to get.
Be ready to mix for a good 20 to 35 minutes.
The color of the syrup will lighten as air get in the mix. Texture and taste will change slowly, real slowly. At first it will taste more like maple taffy and then the texture will get more like icing, with small "crystals" you can feel in your mouth.
Now it's all yours. You will have to try different texture. I prefer more grainy butter, but the rest of the family prefer smoother texture.
You are pretty much done, just fill up some jars, leave it in the fridge. Use it on your toast the next morning, it's fabulous.
Leaving the sticky cookware in warm water overnight is the best way the clean it.
