Introduction: Homemade Battle-Bot (Make It Move)
So... I bet you're wondering how I just made a working combat robot, right? Well, in this case I designed it on Tinkercad, 3D printed it, and fit it with some spare electronics I had. In this tutorial I will guide you through how I made this.
You will need:
-3d Printer
-laptop running windows, macOS, or Linux
-Misc. electronics (In steps)
-some common knowledge of what electronics do what ;)
Step 1: Come Up With Idea
Before you even get started with trying to design a robot, you will probably want to come up with a mechanism for how your robot works. My robot here is called a Full Body Spinner because of the way a "shell" rotates around a separate frame.
Step 2: Design Your Robot
Now that you've come up with an idea of how your robot will work, start designing it!
For this step, I used a program called "Tinkercad." Tinkercad is a 3d designing software that is open source and easy to use. It may take a while to really get good at 3D designing, so watch a lot of YouTube on it and stick with it!
Step 3: 3D Printing Your Bot
If you don't have a 3D printer, you can find other materials like metal or wood to build your bot around. For me, I have a printer which is why I'm making this step.
For my bot, I used a material called PLA. It is very easy to print, and is overall a pretty durable material. You can still use whatever material is best for you, this is just the one I chose.
Step 4: Fitting Your Bot With Electronics
I must tell you before that everybody will do this step differently, so please make sure YOU know what to do.(electronics are dangerous)
For me, I had to use a brushless motor, 3x ESC (electronic speed controller), Receiver, Transmitter (remote control), and a LIPO battery. These components ended up costing me less than $100.
Step 5: Test Your Bot
Once you have fitted all of your electronics into your bot, MAKE SURE YOU TEST IT. You do NOT want to go enter into a competition without knowing if it will work or not.
Step 6: Have Fun!
Yes, your bot is complete! Just make sure you stay safe...
THANK YOU!!!
Project by: Isaiah Schell
For help with this project email: Isaiahmatthewschell@gmail.com
