Introduction: Homemade "Febreeze"
Very cheap alternative to febreeze that WORKS. Been using for a long time.
Step 1: Get an Empty Spray Bottle
You can use the empty febreeze bottle, or buy an empty new bottle at almost any store. i got mine at the dollar store :)
Step 2: Add Water
Add about 1 1/2 cups water to the spray bottle
Step 3: Add Baking Soda
Add one Tablespoon of baking soda. Cheap stuff works. I have also tried white vinegar. Works well if you are afraid the spray will leave spots on your fabric.
Step 4: Add Fabric Softener
Add about 1-2 Table spoons of your favorite fabric softener. I recently tried Tide Natruals, its been my favorite so far, but the cheap stuff works too.
Step 5: Shake Well
After all the ingredients have been added, shake well. Also Shake before each use.
Step 6: Spray Everywhere
Spray onto carpets, clothes, blankets, or anywhere that needs freshening. I use it daily, on all the fabrics in my home. Sometimes it leaves spots on hard surfaces, but easly wipe off with a damp rag. Hope this helps you guys, I had a very smelly room mate, and i always sprayed this stuff in our room and it helped out tons!
Recipe can be doubled, tripled etc.
29 Discussions
Question 2 years ago on Introduction
What is the baking soda for? I loved it whenI made it but it left a residue. Can I leave it out?
Thank you!
3 years ago
Fabris softener is flammable, how flammable do you think this mixture is?
4 years ago
wait, is it febreeze or febreze? I've always known it as febreeze.
Reply 4 years ago
I think the spelling of the name was changed when the formula was sold. I could be wrong because memories are a construct of what the brain wants you to believe.
Reply 4 years ago
The Mandella effect for sure....Ive seen this one. idk what I remember, so weird.
4 years ago
Awesome:)
5 years ago on Introduction
I made this but instead of baking soda I added 2 tbsp of vinegar and 1/4 cup of body spray and it even worked on the dog bed and it lasts 3 times as long as the fancy store bought stuff
I made it a few hours ago, and I used Downy. To me, Downy smells horrible, but I used it anyways. I shook it. As expected, it smelled like dog poop. I added some Calvin Klein cologne to it (literally!) and used it on my rugs. It smelled pretty good, and made them feel new and fresh. Thanks!
i have always made this with just the fabric softener and water. i stumbled on this today and added some baking soda and alcohol to my "normal" mixture - and WOW!
the scent is lasting WAYYYYY longer than normal and my house smells so awesome and clean (BTW - i used Snuggle).
thanks to the original poster, and for the additional comments and replies!
8 years ago on Introduction
If you add baking soda to any of these solutions that have vinegar in them you're probably going to have a mess when it starts foaming up.......I'm going to try the cornstarch with the vinegar and fabric softener......I have used the softener, vinegar and water for wrinkle release spray and it's great....just a heads up on the vinegar/baking soda reaction! :)
Reply 6 years ago
You realize he said to use baking soda, or for an alternative white vinegar. Never said anything about mixing them. Just saying.
8 years ago on Step 6
I used Downey! I love it!
9 years ago on Introduction
In the theatre, there isn't time to wash. Costumes at the end of each performance. What is done instead is the underarm area of the garments are swagger with a cloth dipped in alcohol or vodka. The actors sweat quite a bit because of the hot lights and exertion, and also mor the most part only one of each costume is made. What I am getting at is I think the alcohol is a very good suggestion to whoever added that!
9 years ago on Step 2
little miss caps lock needs to stop shouting.
10 years ago on Introduction
i personally tried a different recipei with one key ingredient! rubbing alcohol. about 1/4 to 1/2 cup. i know your thinking it will bleach the fab. but it wont. the purpose of the alcohol is to make the water and other liquid contents evaporate more quickly. give it a shot. (in industrial settings they add it to mop water, window cleaner, and carpet cleaning solution to make it dry faster so they dont have to block rooms off for hours-its called QUICK DRI) P.S. MY RECIPIE: 1/2 CUP LAUNDRY DETERGENT (CUTS GREASE AND DISENFECTS) 1/4 CUP 3% HYDROGEN PEROXIDE (ANTI-GERM, ANTI-FUNGAL, ANTI-MOLD, AND BACTERIAL) 1/4 CUP RUBBING ALCOHOL (QUICK DRY) 2 CUPS WATER. *CLEANS AND DIS-INFECTS AIR AND FABRICS.*
IM GOING TO USE 1 1/2 WATER AND 1/2 CUP VIN. IN MY NEXT BATCH BECAUSE I HAVE USED VIN. TO CUT ODERS BEFORE. THE ACID IN THE VIN. KILLS THE ODERS.
I know this thread/post is kind of old but I have some information about your post nikholemarie. Don't use vinegar in addition to the recipe posted in this instructable. You have to choose between either peroxide or vinegar. The reason for this is explained in this quote from another site I found while researching this.
"When cleaning with vinegar, make sure that it does not come in contact with hydrogen peroxide. Mixing the two will create Peracetic Acid (C2H4O3).
The toxicity of Peracetic Acid is low. However, peracids are extremely irritating to the skin, eyes, and respiratory tract. It has a strong oxidizing potential, is highly corrosive, and can explode at temperatures exceeding 110ºC."
Thanks for that info. Too bad I didn't read it until I commented above... ;) Thanks for your recipe... :)
12 years ago on Introduction
Cheap vodka works surprisingly well, too. It's excellent at removing smoke odors.
RUBBING ALCOHOL IS EVEN CHEAPER. AND MAKES LIQUIDS EVAPORATE FAST.
