Homemade Thumbscrew
Intro: Homemade Thumbscrew
This instructable will show you how to make a custom thumbscrew with parts you probably having lying around. You can go to step one now or read the back story as to why I can up with this.
Back Story
I am in the process of buuilding a custom folding-hideway workbench. One of the things I want to do is have mounting points for my tabletop devices such as a Drill Press, Dremel shaping table, vise etc. But because the bench top folds away I need to be able to securely attach and remove the tools easily. So I will be putting threeded insert screws in the bench top in the appropriate places for my bench top tools.
I also wanted to be able to loosen and tighten the screws by hand so I didn't have to worry about having wrenches or sockets available.
My initial idea was to use 1" knobs that had the correct thread bolt in them. But they cost anywhere from $5 to $15 each and I need at least 12. So I set out to make something cheaper.
STEP 1: Supplies Needed.
- A screw or bolt. ( I used a 1/4-20 screw, but any size to match your application will do)
- A nut (to match thread of bolt)
- A washer (to match diameter of bolt)
- Loctite Red (or any high strength thread locking glue.)
STEP 2: Apply Loctite
Following the directions of the adhesive you are using, apply some to the tip of the threads.
STEP 3: Thread on Your Wingnut\washer
Put the washer on first, then thread on the wing nut. I went one thread past the end to make sure it was secure. You will need to wait until the adhesive sets. In the case of Loctite Red, it's about 20 minutes.
STEP 4: Cut Off Head of Screw
Now that the wingnut is secure, you can cut off the head of the screw or bolt.
STEP 5: Clean Tip of Threads and Test
Depending on how you cut the head off, you may need to clean up the tip a little to allow a nut to be screwed on. Once cleaned, use a nut or, in my case a threaded insert that this will ultimately be used for, to test the threads on the cut off end.
STEP 6: Test in Your Aplication.
This is one of the tools I will be scuring with these thumbscrews. The bench is not built yet, so this is a scrap piece of wood with the threaded insert installed.
As you can see in the second photo here, the screw is too long and will not tighten down. You have a choice here. You can either cut the screw a little shorter, or, as I did in the last photo, I just added a nut to it. Now it tightens down. I prefered this way because this now allows me to use the screw for other devices that may need the screw to be a bit longer
STEP 7: Addendum: Alternate Means to Attach Wing Nut
Based on some users suggestions, I'm showing an alternate way to attach the wing nut to the bolt or screw. Thread the wing nut onto the screw so the "wings" are facing the head of the crew. Thread the wing nut up until tight
Based on the screws I was using, the head of the screw was too wide, so I marked off the excess part of the screw heard and grinded it down so it was as thing as the wing nut. If you use this method, be sure to wear gloves. The screw will get hot.
Once you have the head shaped the way you want it, secure the wing nut with Loctite, solder or weld.
I found this process a big cumbersome and for my liking, I will probably stick with my original process. However, I will put a nut on the screw so that once the head has been cut off I can remove the screw to repair any threads that may be damaged due to the cut.
19 Comments
ajoyraman 7 years ago
Nice work! If you screw on the nut before cutting, clean out the end and then unscrew the nut, the threads come out perfectly as the nut acts as a die forming the threads while it unscrews.
rsmaudsley 7 years ago
I thought about that, AFTER I had made this Instructable. I need to make a bunch more so I will try it.
Paxman5 7 years ago
Why not cut of the screw head first and then screw on the wing nut the wrong way. Then apply the locktite to the cut end and thread the wing nut all the way up? This way the machined end of the thread will be unharmed.
Paxman5 7 years ago
Maybe my previous post was a little unclear. What I ment was that you screw the wing nut on the normal end of the screw, but reversed with the wings towards the end where the screw head has been cut. English is not my native language...:)
Paxman5 7 years ago
Just saw that you added my suggestion to de instructable. However, it was not really the way I was thinking of doing it. Do as your first image, but don't apply the loctite and turn the wing nut around with the wings towards the cut end. When the screw head is gone, apply the loctite on the cut end and screw the wing nut all the way up. This way it will actually be less cumbersome since you won't need to bother with getting the threads cleaned up. The messed up threads will even help the loctite ever so little when they are inside the wing nut.
krieglers 7 years ago
I have done this in the past without the loctite, I cut off the head screw the wingnut to the top, and apply so Silver Solder or Soft Solder. The upside is this way you have the original thread. The Down side is you need to clean off the Flux and polish the wingnut
TechDoofus 7 years ago
As long as the head of your bolt isn't too big and the wings on your wingnut are large enough, why not tread the wing nut UP the screw to the top of the nut. No cutting required then.
throbscottle 7 years ago
Also this way you can lock the wing nut against the bolt head, which I would trust more than the Locktite alone. You can always file down the head a bit if it's too big.
This might be possible if the screws were a small thread. Plus, I was using what I had laying around. But the heads are V shaped, so maybe this will work. I'll give it a try and post how it goes.
Drake88 7 years ago
One thing about Loctite and other threadlocker compounds - eventually they will fail. Sometimes it can take dozens of years, but it will happen. Making a small cut in the end of the screw after putting the wingnut on, then screwing the wingnut up to the end, and using a punch to spread the end of is another way to lock the wing nut permanently. Another good way is to use a propane torch to melt some solder into the threads - you don't have to braze it, just using some non-lead solder usually does the trick.
reborne 7 years ago
Drake88 7 years ago
Not hard to find one in a well stocked hardware store - look for those little external cut-off pinch-screws used on thin hose. First time I saw one, I wondered why we stocked torture devices in hardware stores(I was about 12 an taking a course on the Middle Ages, and had just finished a report on the Spanish Inquisition). I found out later they were used to reduce or cut-off the flow of liquids in thin flexible hoses. Made for a funny conversation with my father at the time, though.
lovethebackwoods 7 years ago
First thing I thought of, too! (What is wrong with us?!...)
f5mando 7 years ago
No!
ddavidadams 7 years ago
If you put a nut on before the washer and wing nut you can use it to clean the threads after you cut the bolt. Simply cut the bolt then unscrew the nut and it will clean off any burrs from the cutting.
Drake88 7 years ago
Aww .. ya beat me to it. I've been using this trick ever since I was around 8 years old, when I helped I dad make a stand for a little drill press he bought. He was working as a machinist at the time, and showed me the trick. It does help some to use a little sandpaper on the end threads after removing the nut though.
DBIASI 7 years ago
It's like to melt a FERRARI to make a Volkswagen... or a bike...
Trike Lover 7 years ago
A couple of thoughts that may add to your very helpful Instructable. #1, (if using a carriage bolt as in the pictures) is to run the wingnut up the length of the bolt from its finished end, and with a file or Dremel tool round off the squared section of the bolt, just below its head. Mix up a small amount of JB Weld or Plastic Steel epoxy - the putty kind works best. Run the nut up as far as it will go, with the wingnut wings up, then use the JB Weld to fill in the area between the wings of the nut and the now-rounded section of the bolt. This gives a larger, smooth gripping area, and no need to re-form cut threads.
#2 is to cut off the bolt head and run the wingnut up the bolt from the finished end. To increase the gripping surface, get a couple of large fender washers, tape off the hole on the outside of each, and then sandwich the wings of the wingnut and the bolt shaft between the two, again using JB Weld or similar epoxy to fill the space between the two washers as well as anchoring them to the the wingnut and the bolt shaft. "Permanent" Loctite is put on the threads between the wingnut and bolt threads first, and a small length of the bolt is left sticking up between the wings.Then file flats on the bolt so that the fender washers lie on a flat surface across the bolt and wingnut wings. This adds a gripping surface 1 inch (2.5 cm) or more. If your fingers have a touch of arthritis, this helps quite a bit.
I have also seen welders extend the wings of a wingnut by slicing a large washer in half using a cutting disc in an angle grinder, then welding the two half circles, round side up, to either side of a small wingnut. That is then put on the bolt as in this Instructable. This greatly increases the gripping area. The same method could probably be used with epoxy putty; the pieces would need to be clamped together while everything sets.
daytona675 7 years ago
if you thread a nut onto the bolt before cutting it, then unscrew the nut from the bolt after cutting the nut will reform any damage to the bolt threads
