Introduction: Homemade Water Filter
This water filter is one you can make when you are out in the woods and need clean water, well you can build this one as long as you have the materials.
Step 1: Gather Materials
1. Water Bottle-To gather all the materials inside it to make the water filter work
2. Gravel- To hold the bigger dirt and rocks
3. Fine or Course sand- To help hold dirt which passes through
4. Cotton - To clean out the dirt
5. 5 coffee filter - Helps to hold or filter the dirty dirt in the water
7. 2 Elastic Band-To hold the coffee filter tight
Step 2: Cut Out Bottle
Get a pop bottle and cut out the middle of it and flip it upside down into the bottom of the bottle
Step 3: Cloth Filter
Use an elastic and put it around the coffee filter around the cap of the bottle and make sure its tight
Step 4: Add Cotton
Put 2-3 cotton balls at the tip of the bottle
Step 5: Add Gravel
Get a handful of gravel then layer it on top of the cotton ball
Step 6: Filter It
Put another coffee filter on top of the gravel and make it as flat as you can
Step 7: Add Sand
Layer a handful of sand and layer it on top of the coffee filter
Step 8: Filter It Again
Put another coffee filter on top of the sand
Step 9: Add Gravel
Now this time you add two handfuls of gravel on top of the coffee filter
Step 10: Filter It
Put the coffee filter on top of the gravel
Step 11: Add Sand
Now put as much sand as you want
Step 12: Filter It for the Last Time
Put the coffee filter over top of the sand and make sure you use the elastic band to make it tight
Step 13: Now Start Filtering Your Dirty Water
Pour the dirty water into the bottle and watch it turn into clean water and then enjoy!
