Introduction: Homemade Hot Pad Patterns Out of Felt
Hot pad is common used in the household. Hot pad patterns I often see are made of wood, most of which are in round shapes. Here how to make hot pads is mainly made of felt. And it is in a shape of maple leaf.
The hot pad patterns have a loop at the leaf, with which you can hang the hot pads on the wall when you don't use them. No more descriptions, I'd rather show you how to make hot pads right now and let you see what it is.
Step 1: Step 1: Cut the Felt Maple Leaf
Prepare materials and tools first in the picture 1. Cut off the felt maple leaf as the paper pattern you have drawn. Cut the other two pieces in different sizes; lay them together with the largest one at the bottom. Cut a small strip.
Step 2: Step 2: Make Loop to the Pad
Sew two apparent lines on the strip piece. Place the strip on the left side of the root of the leaf; fix it with pins. Sew the loop with and leaf. Sew apparent line in the center of the leaf from root to the leaf top.
Step 3: Step 3: the Ending Work
Sew the other apparent line nearby. Do the same to sew the apparent lines dispersed from the middle lines. The lines are the stems of the leaf. Each stem has two lines in order to make it the pad more endurable.
