Introduction: Honeyduke's Chocolate Frog Box
After many hours of searching the web for the perfect printable template for a Honeyduke's Chocolate Frog box, the web seemed to come up short. I ended up downloading what appeared to be a scan of a used box (crease lines and all) and modifying it heavily in Photoshop myself. I'm providing that edited template along with a star pattern I created for the inside of the box in a zip file with this tutorial. You'll need to download it and extract the files before you continue.
Also, make sure you have the following:
- Scissors
- Permanent double sided tape
- Heavy card stock paper
- A printer
If you're interested in making the Chocolate Frog cards as well, you can view those instructions here!
You'll also need to download my free templates available below. I am not referring to the instructables PDF (which requires a paid subscription). You want to download the .zip file.
YOU MAY *NOT* USE THESE TEMPLATES FOR PROFIT
Step 1: Print the Template
The first thing you'll need to do is print the images from the zip file onto a sheet of card stock paper. Print the front of the box on one side, flip the paper over, put it back in the printer, and print the star pattern on the other side.
Step 2: Cut the Template Out
Next, cut out the template. Follow the lines as closely as you can, making sure to not leave any white around the edges. There are small tabs that you can safely cut off. Refer to the images above.
Step 3: Fold and Crease
Now you'll want to fold the flaps and make creases in the bottom side of the box. You will basically want to fold and crease the box everywhere you see the borders with the small circle patterns. Refer to the images for reference.
Step 4: Apply Double Sided Tape
Apply strips of double sided tape around the inside of the box as shown in the images above. You'll want to add small pieces of tape to the little triangle folds in the corners of the box as well, and a couple of thin strips to the top of the box.
Step 5: Fold Again
Fold in the small triangular corners and crease them. You will want to push them against the edges of the double sided tape you applied to the inside of the box and then pinch them so that the smaller pieces of tape you applied to the corners hold them closed (See the first and second image above).
Once that's done, fold the flaps down on all four sides of the box and pinch them against the strips of double sided tape.
Now pull the edge of the top of the box, where you applied tape, under the other side. Line up the word "Frog" and line up the circle pattern at the bottom, then pinch along the overlap to get the tape to stick.
Once you have finished this, close the box.
Step 6: You're Finished!
You're all done!
This was kind of difficult to explain with all the folding, creasing, and taping. I Hope the images help!
Let me know if you liked this tutorial and post your own Chocolate Frog boxes in the comments!
Don't forget to check out how to make Chocolate Frog cards, too!
Halloween Props Contest 2015
First Time Author Contest
Papercraft Contest 2015
7 People Made This Project!
- CrafTea Cosplays made it!
- ChanK18 made it!
- Lahjnea made it!
- TiffanyK38 made it!
See 3 More
47 Comments
3 months ago
I may be a bit slow, but I can't work out where the actual template is. Am I missing something?
Best Answer 3 months ago
Check the very bottom of the intro step, you'll find the zip file there.
11 months ago on Introduction
I know it says we may not use this for profit but I’m making other items which is my own which is for sale like candy and stuff.. can I use these boxes to look like cool Harry Potter themed boxes they can come in like free with the candy?
Question 1 year ago on Step 1
Sorry, but what paper/card stock size did you use?
Question 1 year ago
I definitely screwed something up. Any chance you could share a video or more photos? My non engineer brain is struggling.
2 years ago on Step 6
I just made four of these for my nephews, they look amazing. Thank you SO much for these, they are really gorgeous, not sure if I even want to give them away!! Much appreciated :) :)
6 years ago
Hi, I'm on my third trial box and no matter what I do I can't get the top to fit the bottom of the box. I did see your comment about the dots bordering the top and bottom of the sides but no matter how I fold it, it makes no difference. Any suggestions? I can't figure out what I'm doing wrong.
Reply 6 years ago
Sorry to hear you're having trouble. From your photo, it looks like the corners of the box are a bit loose. Try folding them in tighter so the sides of the box aren't 100% vertical. They should be at a very slight inward angle. Does this make sense?
Reply 3 years ago
This tip made a world of difference for me. Thank you!
Reply 6 years ago
I'll give it a whirl. I'm determined to make this work. Thanks for the reply!
3 years ago on Introduction
So so so so glad I found this tutorial! I didn't want to have to purchase these but needed them for decor for halloween ! Thank you so much!
4 years ago
Hello! Thank you for this tutorial, we followed all the directions but the box won’t stay closed? :/ is there something you recommend for this?
Reply 3 years ago
Well the only thing I can say is make sure the triangles near the hinge part are taped together
Reply 3 years ago
Exelente
Tip 3 years ago
If you don't have color ink, you can still do this, but you might want to have a gold pen to color it in
Question 4 years ago
Can you send the file since you had to take it down I would really love this and the inside cards
4 years ago
Can you upload the files please?
hi! I love these and am throwing a harry potter themed graduation party for my daughter and your chocolate frog boxes would be such a wonderful addition to the party. i am just having trouble finding the zip file you mentioned. where do i find it so i can download and start creating?
Question 4 years ago on Introduction
Can you tell me what # the cardstock is? I ordered 80lb. glossy paper and it was too flimsy.
Answer 4 years ago
100lb card stock should be perfect.
