Introduction: Hot-Wire Foam Cutting Nunchucks
If you've ever tried cutting foam with knives, it can be a frustrating ordeal. With a material that absorbs a lot of shock, you can't apply sufficient pressure to cut through it. The solution? BURN through it, with your very own hot-wire foam cutter/ nunchucks!
With all the parts parasitized from old, and unused everyday items, you can build this foam cutting contraption for less than five dollars! We did it for $3.50, INCREDIBLE! So let us begin our amazing journey to the world of ninja foam cutting....
WARNING
This project uses high current and hot wires, so don't burn/ electrocute yourself. Also, beware of toxic fumes, and work in a well ventilated area.
Step 1: Materials Needed...
MATERIALS
1. (1) Old hairdryer
2. (1) AC power adaptor, at least 1 amp
3. (2) Pieces of 1/2" PVC, about 8" long
4. Electrical tape
5. Silver bearing solder
TOOLS
1. Soldering iron
2. Means of cutting PVC pipe
3. Ninja
4. Pliers
Step 2: Take Apart the Hairdryer
Disassemble the hair dyer and take out the heating element. On the heating element, there should be coils of thin wire. This is nichrome wire. When current is passed through it, it heats up because it has very high resistance. This property makes it perfect for cutting foam. However, be aware that if the wire you use has too little resistance, you can destroy your adaptor, which is never fun.
Un-wrap the wire coils from the heating element's frame, and snip off a small piece that will straighten out to about 8". Proceed to straighten out the wire with a pair of pliers.
Step 3: Attach Power Adapter
Strip off about a 1/2" piece of insulation from the ends of each of the two wires on the power adaptor.
Then, take the straightened 8" piece of nichrome wire and solder both leads form the adaptor to opposite ends of the wire. Be aware that nichrome doesn't solder very well, and it may take a few tries. Add a switch if desired.
Step 4: Finishing Construction
Tape the wires from the adapter to the pieces of PVC pipe as to make two handles (use different colors of tape for class). Notice the nunchuck resemblance? This will make it so you don't burn yourself, and can cut the foam with ease.
Step 5: Cut Your Heart to Contentment?
When you are ready, plug in the adapter and observe that the wire heats up very quickly. Now that the wire is hot, you can cut through many things, including most types of foam, cardboard, paper, and your own hand (though not advised). Enjoy cutting foam with ease and precision, AND enjoy laughing at your friends while they struggle with their knives and razor blades.
79 Comments
6 years ago
Will this cut through Styrofoam?
6 years ago
only one amp?
13 years ago on Introduction
Reply 13 years ago on Introduction
No. It is no more safe inside, this is not a dangerous current. It is safer to have it outside so you can see if it is getting hot enough to melt the PVC, and that it cools at a more rapid rate outside. However, the whole idea of using PVC is pretty terrible. Far better would be to use regular copper pipe, this way it's quite heat resistant and it slightly heatsinks the ends of the nichrome wire which is desirable, preserves solder joints too. However, it should not use solder joints at all actually. The proper method of construction with nichrome wire is a mechanical one where it's crimped, screwed, or riveted onto the holder. Finger shields seem pretty pointless. If your hand slips so easily it is advised to wear thick heat resistant (like leather) work gloves.
I would probably highly recommend against using any form of conductive pipe at all. The idea of something a bit nicer than pvc is probably a bit un-needed at 12vdc. I mean I guess if you maybe coated the pipe so it would no longer be conductive that it might work but just be careful.
During my quick review I would highly suggest against the copper pipe rout if your using 1 amp dc adaptors or more you only need about .85 amps or so to stop your heart under certain conditions.
This is incorrect. Far far less than 0.85 amps can be deadly BUT it is not current that kills (per se), it is voltage. Even a few dozen mA is deadly but won't flow without the voltage to push it. You are plenty safe holding some copper pipes, BUT you don't necessarily need to hold onto the bare copper, might as well wrap some tape around them or wearing gloves is even better so your hands have the most reasonable protection possible. The far more reasonable risk to be concerned about is accidentally burning yourself when nichrome wire hot enough to melt foam comes in contact with a material like PVC that melts, and/or gets brittle after exposure to this much heat. At least if it melts you have a more gradual warning but if it gets brittle then the next time tension is placed on it, it could snap apart and the heated wire flies towards whichever arm is holding the end that didn't break. There are several ways the nichrome wire could be well enough insulated, and/or a holder resistant to heat like metal pipe could be used, OR you could do both, use a heat resistant pipe AND both thermal and electrical insulation from that pipe. We need to keep something else in mind though, others have compared licking a battery but not what is happening when you have a nichrome element between two copper pipes. In such a situation the nichrome wire is a load, it is substantially reducing the voltage below 12V. You could probably jump in a pool and be dripping wet, lick one pole while putting the other under your armpit, and never feel a thing with the nichrome wire pulling the voltage down to almost nothing, it would probably read under 3V.
Then how do you explain 100KV stun guns? Or electric fences? Amperage is the "push" in the equation, not voltage.
Basic science. Voltage is a difference in potential, that potential is what determines how much current will flow until you reach the limit of the power source. A stun gun is an example of what I wrote, kilovolts of electricity just to make a few milliamps of current flow. Amperage is not the push, it would be like you pushing a brick across the floor and YOU are the determing factor of how far the brick is pushed up to the maximum force you can exert on it. Current is then akin to the weight of the brick, the quantity being moved. Therefore, we don't have to be concerned about the current. If you touch two electrodes with 2 volts and 20 million amps from a power source it will not hurt you. If you touch two electrodes with 2000 voltags and 200 milliamps, you better hope you let go while your body uncontrollably shakes.
If you are still around and wouldn't mind, may I pose a question about a commonly seen scenario involving cardioversion or defibrillation using electric current?
Reply 11 years ago on Introduction
Tell me if I'm wrong here but in your analogy wouldn't weight and quantity of bricks being moved be better compared to resistance in a wire? and so the current would be represented by the speed at which the brick would move?
wow- your smart, i don't know a thing about electricity, should i stick with 1 amp for this particular experiment?
You don't need to limit current, only voltage to the extent that you use high enough voltage to force the needed amount of current through the wire element.
For example (and I am making up numbers, not measuring a real cutting wire), suppose when the wire is hot enough to cut foam it has 5 ohms resistance, you would be (if using parts on hand) stringing the wire and applying increasing voltage until the wire becomes hot enough to cut the foam. What voltage that needs to be depends on the specific wire you use and how long it is.
Suppose you need 30V to get it hot enough, and it is 5 ohms resistance, then 30V/5Ohm = 6A using a basic ohm's law equation, meaning your PSU would need to be capable of at least 6A, but it could be capable of more than that current and be even better because then it isn't running at full load which could be stressful to the PSU.
gg
Probably should mention that I built this at my friends house in under an hour, using largely what we had lying around. I would have used steel screw eyes, and PVC end caps to secure the wire, but we didn't have those on hand. As for the copper pipe, I think that would conduct too much heat away from the wire, and it wouldn't cut very well. Feel free to improvise off of the design, this project was very unrefined.
Wow... is there anything you don't know? jk.
im not lol
If there is significant heat that would be conducted to the copper pipe, that is probably too much heat for the PVC (gets very bittle subjected to heat, if it doesn't outright melt), and for the solder joints. I don't know the resistance, how hot the particular nichrome wire you use will get with a mere 12V/1A supply, but generally speaking since the entire length of the wire would get hot, 'sinking away heat at the ends could be a positive thing since a thin wire by itself doesn't conduct very fast and you would be cutting somewhere a distance from that spot. The copper pipe seems ideal also because you're not trying to solder wires to the nichrome, you can tap a threaded hole into the copper and solder the power lead to the copper further down on it (use a blowtorch to heat the copper pipe in a vise with some flux and solder on it and the wire will solder on from that residual heat stored in the copper pipe). Copper cuts fine. Use a hacksaw or regular pipe cutter, then a piece of sandpaper or a file. Pipe finishes quite well with fine grit sandpaper or even metal polish if you want it mirror-like though of course being copper it will eventually dull in color from exposure to air, but actually it finishes better than PVC due to being able to bend, sand or polish it. We are doing what we always do though, suggesting things that go against your goal which was getting the job done with parts on hand. Given only the parts you had it is proof enough that it worked... I just don't know how many times PVC would hold up to being heated by the wire and when suggesting the copper pipe it was just one alternative, some people might have spare copper pipe instead of spare PVC lying around.
You could on the other hand still use pvc if you had some sort of heat resistant insulating medium (porcelin is a good choice) at the connection between the hotwire and the cords and where it meets the PVC handles. You wouldnt have to worry too much about the heat ruining the PVC with this method. I believe that you probably would have plenty of warning as well if the pvc was degrading too heavily due to heat damage and would be able to give it some cooldown time. I normally wouldnt go into detail like this but I just dont want instructables to make the next darwin awards.
damn beat me to them. I had the same thoughts
