Introduction: How I Fix a Hole in a Wall With Friable Plaster ...
About: Hello! I’m a DevOps engineer working for a major German telecommunications provider. Alongside my professional responsibilities, I am dedicated to training the next generation of talent in our field. In my fre…
I live in an old House with friable plaster on all walls and I have always problems to fix something on the walls. One morning I woke up and my blind layed on the ground and I had a hole(60x25x20) in the wall where the blind was fixed ...
100 years ago they used pieces of wood to fix blinds, the orginal one was broken and I usually haven't pieces of wood in my flat ...
But I have a 3D printer :-)
So I created a block which fits the hole, the sides are ripply to increase the friction and a lot of screwholes to fix my blind one the right position ...
... problem solved ...
Step 1: Create the Replacement Block in Fusion 360 and Print It ...
I measured the size of the hole, it was circa 60x25x20.
So I created a block wih a size of 55x20x20, I sketched 8 circles on top on every side ...
I added every uneven circle to the block and I removed every even circle...
I added 27 holes on front sides which fits to my screw size ...
After that I printed this block ...
Step 2: Plaster the Block Into the Hole ...
I mixed plaster and filled the half hole ...
After that I put the block into the hole and removed surplus plaster ...
I waited one day to let the plaster dry ...
I fixed the blind on the block ...
