Introduction: How to Acid Etch Concrete
Etching Concrete With Muriatic or Phosphoric Acid
New and existing bare concrete substrates should be cleaned and etched to ensure proper penetration and adhesion of paints, sealers, stains or textured coatings. Failure to achieve a clean uniformly porous surface could result in a poor appearance and/or premature coating failure.
Step 1: General Surface Preparation
Basic Cleaning: All dirt, oil, grease, wax, dust, release agents or other contaminants should be removed prior to etching the concrete. Oil and grease stains can be removed with a good quality oil stain remover. Dirt, grime and other debris can be removed by pressure washer and scrubbing with a good concrete cleaner. If necessary, curing agents or sealers should be removed by chemically stripping or mechanical means using a floor grinder or scarifier.
New Concrete: New concrete should cure a minimum of 28 days. Any surface imperfections should be removed by mechanical means. Holes, cracks, and other voids should be filled with appropriate filler.
Painted Concrete: Remove any loose or peeling paint by scraping, wire brushing or power washing. Paint edges should be feathered by sanding as needed. Small exposed areas should be wire brushed to remove any laitance or other contamination prior to priming. Large exposed concrete areas should be treated as unpainted and etched as directed by choice chemical. Widespread adhesion failure could indicate the need to completely remove the existing coating by power washing, power tooling, paint stripper or other means to ensure adhesion of the new coating.
Step 2: Etching Solution
Type of Acid: Out of the variety of acids available for etching concrete (muriatic, sulfamic, phosphoric, organic salts or citric), muriatic (hydrochloric) and phosphoric acids are normally the products of choice. Muriatic acid, also known as hydrochloric acid, should only be used where chlorides are permitted.
Container/Acid Ratio: Acid resistant containers (plastic) should be used for mixing and spreading acids. It is essential to calculate the dilution of acid to water since commercial containers may vary in concentration. Typically, muriatic acid is usually mixed at a ratio of one part acid to three parts water in order to reach a required level to adequately etch bare concrete. Phosphoric Acid is mixed at one part acid/cleaner to one part water. Questions about mix ratio should be answered by the company that supplied the acid to you.
Determining Acid Strength: The best method for determining muriatic acid concentration, is to test the substrate with a very dilute solution, then add acid to the container as required until a strong bubbling action is observed in the test. This will confirm the amount of acid concentration needed for the project.
Step 3: Dampen the Concrete:
Pre-Wet the Concrete: The concrete surface should be pre-wet with clean, potable water. The substrate should be uniformly wet without any puddling or standing water. The concrete should remain wet until the acid solution is applied. Note: The area being treated should be done in small sections so the concrete does not dry out before applying and working the acid.
Step 4: Apply the Acid Solution
Application of the Acid: The acid solution should be applied uniformly over the surface of the concrete. An excellent means of application is with a plastic garden sprinkling container. The fresh acid should be deposited in a consistent manner over the entire surface so the etching results will be uniform. The acid solution should not be dumped onto the floor and swept over the surface. Acid spread in this manner will be partially spent and will not yield uniform results. The acid solution will begin bubbling indicating it is reacting to the surface layer of concrete. Any areas failing to produce the bubbling action would indicate the area has contaminates that are preventing the acid from reaching the concrete. It will be necessary to properly clean and re-etch or prepare these areas by mechanical means. The acid solution should be scrubbed thoroughly with a stiff bristled brush during the application process.
Allow Acid time to React:The acid solution should be allowed to remain on the concrete as long as the bubbling continues (usually 2-10 minutes, however, this would depend on the floor conditions and acid concentration used for the project). The floor should not be allowed to dry out during the acid etching process.
Rinse the Concrete:When the bubbling action of the acid solution slows down, spray the area with a generous amount of water or first spray a solution of one pound of baking soda in five gallons of water to neutralize the acid and then flush with water. For proper disposal of all liquids, use a wet vac if no drains are present. The surface should have a uniform texture of medium grit sandpaper, if not; the acid etching process must be repeated. The substrate should be flushed two or three times while scrubbing with a stiff bristle broom in order to remove any existing powdery residue. To avoid possible adhesion failure, vacuum any residue or white powder after the surface is dry (before painting).
Step 5: Neutralize the Concrete As Required
If muriatic acid is used for etching, check the pH of the final rinse water on the wet concrete with pH paper. An ideal pH reading is 7.0 (neutral); however, a range of 6.0-9.0 is usually acceptable for most coatings, unless otherwise stated. A pH range below 6.0 would indicate acid residue remains in the pores of the concrete and must be neutralized. A strong ammonia solution or two pounds of baking soda in five gallons of water will generally neutralize the concrete in one application. The neutralizing solution should be spread uniformly over the substrate in the same manner as the acid solution. The surface should remain wet with the solution for at least ten minutes before agitating and flushing with water as recommended when etching the substrate. The pH should be re-checked and the neutralization process repeated if the pH of the rinse waster is still below 6.0. For a pH reading over 9.0, repeat the rinsing process until the pH is at an acceptable level.
Step 6: Seal the Concrete Before Painting
To help waterproof and strengthen the concrete, apply the Armor S2000 or Armor L3000concrete sealer. It chemically reacts below the surface and is guaranteed to last a lifetime. It will not change the look or color of the concrete and will help increase the adhesion of paints and stains by up to 20%. Learn more about concrete sealers.
The Armor S2000 and Armor L3000 are silicate based sealers, one sodium and the other lithium. The thing about these two sealers is they chemically react, becoming a part of the substrate itself. Acrylic, latex, epoxy, silicone, silane, silane/siloxane, and other types of sealers have a life of 1-5 years and usually start to peel or flake if water or moisture becomes present. The S2000 and L3000 sealers work to keep excess moisture from entering in and penetrating through the substrate. They are the best types of concrete sealers to use and come with a lifetime guarantee.
Step 7: Disclaimer
Disclaimer: The above information is based on available data and is believed to be correct. We make no warranty, expressed or implied, regarding the accuracy of this information and assume no responsibility for injury from use of the product(s) herein described.
