Introduction: How to Cut a Mango
About: I helped start Instructables, previously worked in biotech and academic research labs, and have a degree in biology from MIT. Currently head of Product helping young startups at Alchemist Accelerator, previous…
Mangos are friendly little creatures, easy to slice and easier to eat. If you know how.
Step 1: Cut Sides Away From Pit
Depending on the type of mango you've got, the shape and thickness of the pit will vary. The Manila mango I'm using here has a nice flat seed, while the Hayden/Kent/Atkins mangos have thicker rounder seeds.
Using a sharp paring knife, start just off the centerline and cut parallel to the seed along the long axis of the fruit. If you contact the seed, just curve away a bit to follow the contours of the pit. You'll leave more flesh on the pit, but it's not going anywhere. Once you get a feel for the seed sizes in your mangos of choice, this process will get even tidier. You should see the white pit showing in the center piece when you're finished.
Cut both sides off of the pit in this fashion, and set them aside.
Step 2: Remove Skin From Center Piece
Notch and remove the stem area, as it's usually tough and/or bitter. Continue by pulling the skin off the circumference of the pit; if the mango is perfectly ripe it should come off easily. If your mango is a bit underripe you may need to actually do a bit of trimming with your knife. Hold the exposed center of the seed to maintain a good grip, as mangos can be slippery.
Now that you've skinned the center, go ahead and eat it. This is the best part of the mango, and it's your treat for cutting up the mango for your lazy friends or family. Use your teeth to scrape all of the mangoey goodness off of the pit, then remember to floss. Mango pits are fantastic, but also the best impetus to floss this side of corn on the cob.
Step 3: Score the Sides
Now that you've disposed of the pit, it's time to score the side pieces of your mango.
Make a series of parallel cuts, taking care not to cut through the skin. Poking through the skin results in an untidy mango, dripping mango juice, and sometimes blood. Cut the lines as close as you like, so long as you make at least two of them.
Now, spin the mango 90 degrees and repeat the process.
Step 4: Invert
Now that you've scored your mango, flip it inside out. Just push up on the skin side to create a spiky little mango hedgehog.
Note that if you've made less than two cuts in either direction, the mango won't have enough flexibility to invert neatly. The more cuts, the easier it will flip and the better it will look. Here I've gone for a middle-of-the-road approach; sometimes I like to have lots of tiny mango spikes.
Step 5: Serve
Place all of your inverted mango slices on a fancy platter and serve. Decorate as you see fit. While small children like the decorated versions, they cannot be trusted to remember that standard googley eyes are NOT edible. Check out Play With Your Food for more edible decoration suggestions.
This is especially good brunch/buffet food, as it's reasonably mess-free and doesn't require utensils. Just hold the mango and bite off the spikes. Alternatively, slice the spikes off at the base for perfectly-sized mango chunks!
