Introduction: How to Make & Use a Seed-Sprouting Bag
Sprouted seeds are a powerhouse of nutrition. You can add seeds to sandwiches and salads, chop them up into dips, or just eat them by the handful.
While they are easily bought in most grocery stores, growing your own will offer you a less expensive, healthier, and more satisfying sprout experience.
There are quite a few methods for growing your own sprouts, but I have found the bag method the best by far. You can spend $15 or more on a sprouting bag, or you can make your own for a few dollars - or less if you already have some fabric on hand that you can use.
What you'll need to make the sprouting bag:
* 1/4 yard or so of natural fiber fabric (cotton or hemp are recommended)
* 1/2 yard or so of ribbon, twill tape, or twine for a drawstring
* sewing thread (to match your fabric if you like)
* scissors
* sewing pins
* sewing machine
* buttonhole attachment for your sewing machine
* tailor's chalk or something else to mark fabric
* seam ripper
* tapestry needle or safety pin
* cigarette lighter or match (optional)
What you'll need to use the sprouting bag:
* seeds intended for sprouting (varieties are practically endless, see step 5 for ideas)
* clean water
* bowl large enough to rinse your finished sprouts
* container to store sprouts in
Step 1: Cut Fabric, Pin & Sew Hem
Decide how big you want your bag to be when it's finished. Mine are 6-1/2 inches wide by 8 inches tall. I start with about 1 tablespoon of alfalfa seed in the bag, and end up with about 1-1/2 to 2 cups of sprouts, and this bag is big enough for that.
Add 1-1/4 inches to the desired height of your bag and 1/2 inch to the desired width of your bag, then multiply the width by 2. (8 inches tall + 1-1/4 inches = 9-1/4 inches; 6-1/2 inches wide + 1/2 inch x 2 = 14 inches.) This will be the size to cut your fabric. I like to make one of the long edges the selvage of the fabric. (The selvage is the edge of a woven fabric that is finished to avoid fraying.) Cut the fabric rectangle.
If you are not using the selvage edge, use the zigzag stitch on your sewing machine to "seal" the long edge of the fabric that will be the top opening of your bag. Now, with the wrong side of the fabric facing you, turn down 1-1/4 inches of the long edge (the selvage if you're using it or the zigzag finished edge if not) and pin in place. Using a straight stitch, and remembering to reverse a few stitches at each end of the seam, sew very close to your finished edge, removing pins as you come to them.
Step 2: Make the Drawstring Hole
Fold your fabric in half, right side out, along the hemmed edge. Use a pin to mark the centerline (where the fold is).
Unfold the fabric and fold the previously seamed hem in half. At the pinned centerline, make note of where the folded top edge is now. Unfold and, using tailor's chalk or a pencil or a crayon or whatever, mark your drawstring hole and remove pin. This should be barely wider than whatever you're going to use for a drawstring.
Using your buttonhole attachment, create a buttonhole around your mark, working on the right side of the fabric. Use a seam ripper to cut the fabric in the buttonhole. Be careful not to cut the threads you just stitched, though!
If you don't have a buttonhole attachment, cut your buttonhole first and then whip-stitch around the hole to seal the edges.
Step 3: Sew the Sides & Bottom
Fold bag in half along the hem, wrong side out. Pin together if you like - my fabric stayed in place nicely, so I didn't bother.
Beginning at the top, using a straight stitch, sew along the side of the bag, leaving about 3/8 to 1/2 inch seam allowance. When you get to the bottom corner of the bag, stitch to 1/2 inch from the bottom edge, and with your needle down in the fabric, lift the presser foot of your machine and turn the fabric 90 degrees. Now stitch the bottom edge of the bag. Be sure to do a few reverse stitches at the beginning and end of this seam to prevent unraveling.
Your fabric edges might be a little uneven - that's okay. Go ahead and use your scissors to trim the edges to about 1/4 to 3/8 inches from your seam. Now run a zigzag stitch along this edge, with the edge of the fabric in the center of the stitch. This is the poor (wo)man's serger!
Step 4: Create the Drawstring Channel
Fold top hem in half toward the inside of the bag, pinning in place. You will be sewing along the first seam you made, so be sure while pinning that your edge is past that seam so you'll be catching the edge when you sew.
With a straight stitch, working on the right side of the fabric, sew along the first hem seam you created in this project. Be sure to reverse a few stitches at the beginning and the end of your seam.
Thread your tapestry or yarn needle with the drawstring you're using, or pin a large-ish safety pin through one end of the drawstring. Insert the needle/safety pin in the buttonhole and begin to work the drawstring through the channel, gathering the fabric and sliding it along toward the "tail" of the drawstring little by little. When you reach the buttonhole again, pull the ends of the drawstring even and knot them.
If you use something that will fray, like the grosgrain ribbon I chose, you'll want to finish the ends somehow. You can heat-seal them with a quick flick through a lighter or match flame or you can turn the ends down and stitch them.
Step 5: Growing Your Sprouts
There are so many types of seeds you can sprout! Some to try are: adzuki beans, alfalfa, almonds, amaranth, arugula, barley, black turtle beans, broccoli, buckwheat, cabbage, celery, chives, clover, corn, cress, dill, fenugreek, garbanzo beans, garlic, hemp, kamut, leek, lentils, lettuce, millet, mizuna, mung beans, mustard, oats, onion, peanuts, peas, pinto beans, pumpkin seeds, radish, red popcorn, rice (especially nice are wehani and Thai Red rice), quinoa, rye, sesame, spelt, soybeans, sunflower seeds, tatsoi, triticale, and wheat. Many of these have a lot of different varieties available, so check them out thoroughly. Try mixing several types together for a sprout salad. I especially like alfalfa or clover with broccoli and radish or cress.
Do your research - some of the beans should be cooked after sprouting, as they can be difficult to digest without cooking. They cook far faster after sprouting, though, and are better for you. Some grains and nuts will not really form a sprout, but a nice swelling at the germ of the seed. They are still delicious and good for you.
Put your seed into the sprouting bag and place the bag in a container of cool, clean water. I use about 1 tablespoon of small seed in mine - a bit more for beans or larger seeds. Leave the closed bag in the container of water to soak. Each seed has its own soaking time, so you'll want to check, but most of the seeds I use tend to need 8-12 hours of soaking.
After soaking, swish the bag around in the bowl a bit and hang. You'll want to put a towel or sponge or something under the drip. About every 8 hours or so (you'll get the feel for this with your particular seeds and the type of fabric you use), either swish and dip your seeds in a bowl of water or rinse under running water. Re-hang.
When the sprouts are as big as you want them, remove them from the bag and put into a large bowl of cool water. Turn the bag inside out and rinse to get rid of any hulls clinging to the bag, and squeeze it as dry as possible. Swirl the sprouts in the water, breaking up the mass of sprouts and letting the hulls drift away from the sprouts. When you have as many hulls freed as possible, remove the sprouts from the bowl. You can repeat this process as many times as you like to get rid of hulls.
Return the sprouts to the bag. Go outside and swing the bag around and around in big circles - you're using centrifugal force to get as much water out of the sprouts as possible, because putting them away wet will cause them to go bad very quickly.
Put the sprouts in a clean plastic or glass container. You can put them in a windowsill or other spot that gets indirect sunlight for a couple of hours if you want to let them develop a bit of chlorophyll (turn green). I usually line the bottom of my container with a paper towel and place a piece of paper towel on top of the sprouts in the container, too. Really, you want to keep them from being too moist! Sprouts will keep for weeks in the fridge.
16 Comments
7 years ago on Step 5
Thanks a lot. I'm new to this and your instructions were very helpful.
Stella in Cyprus
8 years ago
Yum! This is great for Thai food recipes! Definitely adding this to my next stir-fry!
11 years ago on Introduction
Thanks! The bags are so ridiculously expensive. I figured I could make one but didn't know how to use it, so I really appreciate the instructions. Sprouts are such a welcome addition to the winter diet, especially since all the store vegies are more than a week old. I'm growing some lettuce under a light but it's not working out very well. I'm going to make a bag this week. Thanks again, makalove!
I love sprouts. I think I will make a few of these for Christmas. Thanks for sharing! Have a splendorous day! Sunshiine
Reply 11 years ago on Introduction
:) Enjoy your sprouting.
I will post a picture when I do. I have so many wanna do's I don't know when I will get to all of them I have a list here on Instructables and what ever inspires me I do. Sunshiine
Yeah, same here. Right now i'm sort of obsessed with sewing fleece cage accessories for sugar gliders.
I want to make one of these for my sister though. I just hope to get it done in time. Sunshiine
13 years ago on Step 4
Hi, this sounds a brill idea, so am about to make my bag tonight, can't wait to try it out. thanks for a great idea.
13 years ago on Introduction
Thanks for this! The fabric bag makes things a lot easier. I had just been using soils and germinating in a regular glass. This works much better.
Many years ago I made radish sprouts for my sandwiches. Then suddenly my source of radish seeds stopped carrying them and I quit. I'll have to check back and see if they have them again.
Reply 13 years ago on Introduction
Check out your local food co-ops and health food stores. When i was in San Antonio back in the mid-90s there were loads of natural foods stores. Personally, i favor the small, locally owned shops over the corporate giants like Whole Foods, but WF should have sprouting seeds too. There are also lots of internet seed shops. Just be sure to use seeds intended for sprouting and not those intended for gardening.
Happy sprouting! :)
That's right. Sun Harvest Foods had the radish seeds in bulk at the time you were here. When they stopped carrying them, Whole Foods had not come to town yet. When they did I checked again for radish seeds but found nothing in bulk. I need to check again.
Awesome! Sprouts really need to be in everyone's diet.
www.theruralindependent.com
Great! Now I'll have even more materials for school sandwich making!
:) I always loved spicy mustard and horseradish type condiments on my sandwiches...now I get those same great flavors in sprouts without adding fat and sugar and preservatives and such. Enjoy your sprouts!
