Introduction: How to Make an Altoids Tin Frying Pan W/Heat Source
You can make an Altoids Tin Frying Pan w/a Heat Source with 1 or an optional 2 Altoids Tins. Cook a small amount of eggs or small pieces of meat in it! P.S. You ---->SHOULD!!!!!!<---- check out step #8 to make the grate holder(It is highly recommended)
Step 1: Get Supplies
1 or 2(preferably 2) Altoids Tins
Hammer
Nail or Awl
Fuel(wood, paper, cotton balls, charcoal or whatever)
Aluminium Foil
Gloves(only use when the step comes up)
Some Effort
And Some HARD LABOR!(not really)
Optional(BUT RECOMMENDED) Step 8 Grate Supplies: Wire and pliers(preferably needle nose)
Step 2: Removing the Lid
IMPORTANT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THIS STEP IS ONLY FOR THE PEOPLE WHO HAVE 2 TINS!!!!!!!!!!!!!!!!
IF YOU DO NOT HAVE 2 THEN SKIP THIS STEP!!!!!!!!!!!!!!!!!!!!!!!!
You have to remove the lid of ONE of the Altoids tins.
Just pry the lid back, and then forward, and it should come off.
If you have trouble doing this (pshh) then watch the video.
Step 3: Lining the Aluminum Foil
Take the tin that still has the lid on and line the bottom and sides of the inside with aluminum foil. This is the cooking surface(for your gourmet meals). Make sure it doesn't rip (I ripped it alot of times. Tip:lay the bottom first, then push the excess aluminum foil to line the sides so it doesn't rip. It took me several tries.)
Step 4: Repeat!
Repeat Step #3 and put another coat of aluminum foil over the first one.
Step 5: Put Fuel in the Heat Source
The heat source for people who have 2 tins is the tin without the lid. You can use wood, paper, cotton balls, charcoal or whatever for fuel since it won't be touching the food. But NOOOOOO plastic(unless you want to die). The heat source for people who only have one tin is an open fire or something like that.
Step 6: Making the Vent Holes
On the tin with the lid, use your hammer and your nail/awl to stab holes in it(while the lid is closed). See the picture?
Step 7: Enjoy!
Put eggs or meat or other foods that are cookable and put them in small amouts on the aluminum foil on the tin that has the lid. Close the lid when cooking. The holes vent out any steam. Put the fuel into the tin with no lid and light it on fire. Place the Fuel Tin(the tin without a lid) on the floor(which I would hope is fireproof(concrete)) and place the "Frying Pan"(the tin with the lid) on thop of it(slightly open so air can come out. (See step 8 if you want to know how to make a holding grate for your Altoids Tin Frying Pan!) Enjoy!
Maintenence: Wash every few uses and replace the aluminum foil very often.
Step 8: *OPTIONAL FRYING PAN HOLDING GRATE INSTRUCTIONS!*
All right. For those of you whose fire goes out when you put your "Frying Pan" on your Heat Source(which is many of you), this is for you.
Grate Supplies: Wire and pliers(preferably needle nose to bend the wire)
All right. This is simple and you can figure it out for yourself(I haven't made it yet) Take the wire, make a stand for your Altoids "Frying Pan" that is bigger than the tin and taller(1 inch)than the Heat Source that has a grate like wiring on the top. I have a picture of the general idea.
17 Discussions
9 years ago on Step 7
awesome i did this too i make noodles while camping out was usefull
11 years ago on Step 7
You should say to have the second tin (heat source) vertical (up-down) and the first tin (cooking surface) horizontal (left-right). Because it needs a lot of access to air for the oxygen, with just a ting gap like what you said might choke it. Or if they make it a huge gap, the food will only partially cook or one side might be burnt while the other is raw. Hope this is helpful?
Reply 10 years ago on Step 7
Not to mention take the paint off the tin. Whew, will that be a fume-ey mess.
-Y
11 years ago on Introduction
This is a great idea! My only suggestion would be that you could punch holes in the sides of the fuel can, so that it gets proper oxygen without a need for a large grill-structure. I'm going to have to eat more Altoids so that I can make this :D
12 years ago on Introduction
Can't believe I never thought to use my Altoids tin survival kit also as a frying pan. This is a great idea. I worry a bit about leeching of the coating of the metal, but I suppose you could sand/scour the surface then toss the tins into a fire for a few minutes to remove the remnants?
Reply 11 years ago on Introduction
That's what the foil is for. The foil goes in between the tin and the food, so leeching doesn't happen. It also makes it easy to clean!
That's a pretty cool idea. Portable bacon!
you should try to make a stand out of the lid that is pried off, like poke some holes so air can go through or sumtin, it would just be cooler. and also, i think you should try to make a handle for the "frying pan" ause itl be hot. im makin this
thanks for all these comments! I hope you like it!
i tryed this is works preety good for in my hut and i go a plasticcube like thing and i ripped the lid of and i put the plastic on and then put the lid on and put popcorn kernals in and tht works good to "REMEBER TO PUT THE LID BACK ON " i didnt 1 time and popcorn went everywhere
cool, glad you liked the idea
it would work a lot better WITHOUT the rack if you cut the same size holes as the back in the front of the fuel tray. you put 2 on the front side, and one on each side side. multiplecats: you want to sand it. also, you want to buy the kind without the letters popping out.
by "letters popping out." i think you mean embossed.
another good idea would be when you are useing the nail and hammer put a few holes in the heat souce for air in the sides
sure. whatever
one other thing you might want to know; you have to have a certain thing on your computer to watch the video. if you have a newer computer than this shouldn't be a problem.
this looks awesome. I saw a different thing that only cooked pancakes. with this, I can cook a lot, and its portable P.S. save the lid so you can take the fuel with you. P.S.S. I can (hopefully) cook pancakes in it!
