Introduction: How to Modify Nerf Raider CS-35 Air Restrictor Valve
In this tutorial, ill be showing you how to upgrade your blaster for a better range and higher power. But be warned, you are modifying your blaster at your own risk :) Show Some Support And Help Buy Materials For New Mods :D (Don't worry it doesn't cost a penny, and takes less than 10 seconds!) Copy And Paste This Into Your Browser: http://bit.ly/16Kvgqj Thank you :D
Step 1: You Will Need...
A small cross head screwdriver, A drill with a drill bit, the size of the bit will be talked about later. A nerf raider CS-35, A bit of time to make sure you get it right :) Also, before we start, any damage you cause to your nerf gun is not my problem. You follow these instructions at your own risk.
Step 2: Removing the Casing
To remove the casing, you will need to remove all of the screws, starting with the 5 that are in the slider handle to reload the blaster! This is where you will need to use the small cross head screwdriver. I also used a small container to keep my screws in - this is optional. Also remember to remove the end cap!
Step 3: Removing the Fixings to the Plunger
On the rear of the gun you will see a bracket with four screws, with the spring in the middle, remove the bottom two and the spring. You will also need to remove the catch with the spring on the top at the very back.
Step 4: Removing the Plunger Assembly
Now you should be able to remove the plunger assembly, along with the metal rod and orange framing. Pull the plunger off the end. Now if you look down the tube, you will see where the tube has lips inside, this is the air restrictor. All you need to is drill this out! Although, how much you drill out will change how powerful the gun is. The more you drill the more power. However the more you drill the more you should pad the plunger to prevent damage when the plunger travels faster.
7 Comments
5 years ago
I found one of these at a thrift store for $5 it doesn't get better than that even came with 6 round mag
6 years ago
if only I could find one of these at a thrift store, last time I went to my local goodwill all I found was amaverick
8 years ago on Introduction
Thanks for the info. It was really helpful. Keep it up.
9 years ago
Cool mod! Nice to see a Nerf Ible! They're so rare on this site nowadays...
Have you tried this rocketeer? it sounds really sketchy with a random link and "the more holes the more power"
No I haven't seeing as I no longer have a Raider... :( I broke mine (dropped it off the roof) years ago in Nerf sniper training...
9 years ago
I'm guessing that this will work on rampage.
