Introduction: How to Remove the Air Restrictor in a Nerf Jolt
Woohoo! Today I'm going to teach you how to modify your nerd jolt! Just go over to the next step to begin!
Step 1: You Will Need...
A small cross head screwdriver, A pair of pliers, Patience (extremely needed, I almost ran out :P) and a bit of time. Remember, before we start, if you damage your gun it's your fault, you do this modification at your own risk. Please support me with future projects by pasting this link in your address bar and following it. It helps me fund materials for more cool instructables! http://bit.ly/1bpoN5k
Step 2: Taking Apart Your Jolt
First of all, you will see 4 screws at the bottom of the jolt, remove them. (Screws shown in picture). Gently slide out the assembly, however when you do this you will need to be pulling the trigger in. For Now, put this aside.
Step 3: Removing the Restrictor Spring
Using your screwdriver, gently hit the spring about until it comes loose and falls out, the air restrictor will now rattle inside the jolt. This did take me about 10 minutes. It's quite tricky so if your really need to do use a pair of pliers.
Step 4: Removing the Air Restrictor
Ok, so you've finally got to that pesky AR. Now the only way to get this out Is to chew it up into pieces with a pair of pliers until it falls out!
Step 5: Overview of the Finished Product!
Ok, I had this one next to my standard jolt and their is no range or power difference. Although, when this is fired without a bullet, it sound 100000x cooler :D Thanks for reading :)
13 Comments
6 years ago
lol I broke the AR does that count as removing it?
Reply 2 years ago
If it's out of the gun then it's removed
Reply 6 years ago
and now there is blue plastic all over my pliers
3 years ago
I’ve drilled and pliered screwdriver and knifed and this little sucker just won’t break
6 years ago
good instructable. I found, however, that using scissors to remove the spring worked well, and drilling the ar a bit before pliering it worked
7 years ago
You have a much bigger chance of breaking your blaster when you dry fire it.
9 years ago
Well, I saw it earlier... But i can find it now either... Hmm... Maybe my phone glitched up... Sorry... :(
But it could still be featured!
9 years ago
Hey! I cant seem to see any of my posts on the front page, are you sure my post has been featured?
9 years ago
Hay man congratz on getting featured!
9 years ago
I'm going to try and keep posting about mods however I need to get some more money for some new guns, thanks for subbing!
Sure! Its good to see another nerfer on this site that posts good quality ibles! ;)
9 years ago
Cool
9 years ago
Cool! Are you going to keep posting mods?
I'm going to sub you now.
