Introduction: How to Build Your Own Moving Tardis!
Get your 'How to build your own Tardis Kit' & another Completed Tardis for scale.
Step 1: Step 1 Open Tardis Kit
Step 1 Open 'How to Build your own Tardis Kit'
Check you have all the pieces you will need!
Step 2: Step 2 Put Lamp in Tardis Top
Step 2 Put White Tardis Lamp in Tardis Top. Use your fingers and press the lamp into the hole in the lid.
Step 3: Step 3 Slide Tardis Bottom on to Tardis Sides
Step 3 Slide the motor and Tardis bottom onto the both sides. Make sure you get the white handle through the correct Tardis side. Use your fingers.
Step 4: Step 4 Click Tardis Sides Together!
Step 4 Checking the 2 Tardis sides and bottom is in correctly press the sides together with your fingers. You n should here a click.
Step 5: Step 5 Click on Tardis Top
Step 5 Pick up Tardis Top. Put Tardis Top on Tardis sides and press down with your fingers until you heard a click!
Step 6: Step 6 Screw in Screws at the Bottom of Tardis.
Step 6
Turn Tardis on its bottom.
Get the four small screws and put them in the holes.
use small screwdriver to screw the 4 screws in the holes.
Step 7: Step 7 Check With Other Tardis Model
Step 7
Compare Tardis model with completed Tardis so far before moving on to the stickers.
Step 8: Step 8 Put on St John Ambulance Sticker
Step 8
Using the sticker sheet.
Pull off the St John Ambulance Sticker and stick it onto the Tardis front.
Step 9: Step 9 Add Pull to Open Tardis Sign
Step 9
Pull of the 'pull to open' Tardis sign and stick on the Tardis front.
Step 10: Step 10 Add the Tardis Windows Stickers
Step 10
Start with thr Tardis front and add 2 windows stickers.
Turn Tardis around until all windows have got stickers in them. You should have 8 windows stickers and 8 Tardis Windows on the Tardis Model.
Step 11: Step 11 Add the Police Call Box Sign Onto the Tardis
Step 11 Add the Police Call Box Sign onto the Tardis
You should have 4 Police Call Box Sign on your sticker sheet. Start at the Tardis front and put the 1st Police Call Box Sign sticker on the Tardis just above the windows. True the Tardis around to add the other 3 signs.
Step 12: Step 12 Compare Tardis With Other Tardis Model
Step 12
Compare Tardis with other Tardis Model to check for errors.
Step 13: Step 13 Turn the Tardis Handle & Watch It Move!
Step 13
Turn the Tardis Handle & Watch it Move!
The Tardis should move 360 degrees in a circle after the white handle on the side of the Tardis has been turned.
Step 14: Step 14 Completed Tardis
The Tardis is now complete and should move 360 degrees when it's handle is turned. Sit back and relax looking at you finished model.
