How to clean your muddy mountainbike This is a cheap way to clean and lube your bike and let it shine like new Always clean your bije after a muddy ride, especially the drivetrain will wear out fast if you don't
Step 1: Tools to Clean
The stuff I used to clean my bike: A garden hose Soapy water Spounge Dishwashing brush Wd40 Towel Rag
Step 2: Hose Off the Whole Bike With Water
Make sure you don't spray onto your bearings and headset
Step 3: Spray the Whole Bike With Water and Soap Espicially the Drivetrain
Step 4: Clean the Casette, Chainrings and Derailleurs With the Diswashing Brush
Step 5:
Step 6: Clean the Whole Bike With the Spounge and Soapy Water
Step 7:
Step 8: Spray Wd40 on the Chain, Derailleurs and Clipless Padels
Step 9: Done, Bike Is Clean and Ready for the Next Ride
Great work! But I have to tell you WD-40 is not a good choice for your chain.
WD-40 gets muddy after a while, and while it does repel water, it also attracts debris and dust, which gets into the links of the chain effectively grinding them from the inside.
I'd suggest using an cycling-specific oil, or a TPF-based lubricant. I can't find either in my country, so I use oil for guns. The oil employed for automatic firearms sticks to the metals, repels water, and lubes parts under violent movements and high temperatures. Those qualities make a great lube for bike chains.
2 Comments
6 years ago
Reply 6 years ago
Thank you for you reply, good advise to use gun oil. I used wd40 because it's cheap.
