Introduction: How to Control Servos Using Raspberry Pi
In this tutorial, we are learning the basics of how to control a servo using Raspberry Pi
You can make a bunch of projects with servos including robots, they are affordable, light, and don't require high voltage.
Raspberry Pi completed with Screen (you can use a TV or and monitor you have), Keyboard and Mouse
Step 1: Wiring: Connect the Circuit
1. Attach male to female jumper wires to the servo
2. Referring to the picture attached, Connect:
- Orange wire to GPIO17
- Red wire to 5V
- Brown wire to GND
Step 2: Script
1. Launch Thonny or Python and paste the script below:
#!/usr/bin/env python<br>import RPi.GPIO as GPIO import time SigPin = 11 T = 0.02 #0.02s, 50HZ pluse_width = [0.0005, 0.0010, 0.00125, 0.0015, 0.00175, 0.0020, 0.0025] #0,45,68,90,112,135,180 def set_angle(angle): GPIO.output(SigPin, GPIO.HIGH) time.sleep(angle) GPIO.output(SigPin, GPIO.LOW) time.sleep(T-angle) def setup(): GPIO.setmode(GPIO.BOARD) #Number GPIOs by its physical location GPIO.setup(SigPin, GPIO.OUT) #set pin mode is output GPIO.output(SigPin, GPIO.LOW) #set pin high level(3.3V) def loop(): while True: set_angle(pluse_width[0]) time.sleep(0.5) set_angle(pluse_width[1]) time.sleep(0.5) set_angle(pluse_width[2]) time.sleep(0.5) set_angle(pluse_width[3]) time.sleep(0.5) set_angle(pluse_width[4]) time.sleep(0.5) def destroy(): #When program ending, the function is executed. GPIO.output(SigPin, GPIO.LOW) GPIO.setup(SigPin, GPIO.IN) #set pin mode is input GPIO.cleanup() def ctrl(angle): n = 50 while n: n = n - 1 setup() if angle == 0: set_angle(0.0005) elif angle == 45: set_angle(0.0010) elif angle == 68: set_angle(0.00125) elif angle == 90: set_angle(0.0015) elif angle == 112: set_angle(0.00175) elif angle == 135: set_angle(0.0020) elif angle == 180: set_angle(0.0025) destroy() if __name__ == '__main__': #Program start from here setup() try: loop() except KeyboardInterrupt: destroy()
* Code sourced from https://www.sunfounder.com/learn/Basic-Kit-for-Ras...
2. Hit [Run]
The servo should rotate
*You can experiment with the rotation of the servo by editing the code just under
Try to delete or change time.sleep from (0.5) to your desired time and figure out what's suits your project
