Introduction: How to Cut a Wig Into a Bob? Step-by-step Guide.
Cutting your wig into a bob is a great way to change styles and looks. If you want to refresh your hairstyle, here are the step by step on how to cut a wig into a bob wig.
Cutting a bob wig is easy for you.
Step 1: First, Prepare
Gather the basic tools including your wig, a wig stand, sharp scissors, a wide-tooth comb, and hair clips.
Put the wig on the wig stand, and smooth it to remove the knots with your comb. Attention the wig needs secure in place and the wig stand needs to stay in a stable place.
Step 2: Second, Decide the Length and Section
Determine the length you want and part your wig from ear to ear. The bob wigs always fall above the shoulder, you can create a shorter or longer one. Use the clips to secure the rest of the wig and keep the section that you are ready to cut loose enough to make sure the hair cut smoothly. It is to note that the part needed in line and horizontally should be at the nape of the neck.
Step 3: Third, Trim Back
Comb the loose section and make sure it's smooth. Then, hold the hair by your finger and trim it slightly across in a straight line. Attention trim the hair length longer than you want to avoid fault.
Repeat the process of part and trim until they are all symmetrical. Check all sections are straight and balanced. If they are not, make any necessary adjustments to achieve the length you want.
Step 4: Four, Refine and Style
Four, refine and style
Blend the ends of hair and refine the cut to soften the hair, and you can use heating tools to achieve your desired look.
Step 5: Final
This is the process of cutting a bob wig, it is funny and easy for you to create. It is essential to cut it in carefully and cautiously to make sure the line is straight and the look is pretty.
