Introduction: How to Do All Keys Lost Programming for Toyota Reiz 2010 G Chip
Here share a Toyota Reiz 2010 G chip all key lost programming method.It is easy for skillful auto locksmith,but useful to freshman,hope it helps!
Step 1: Remove the Immobilzer Box
The immobilizer box located over the air conditioning evaporator and near the console.It is not difficult to remove it,it will take you about half hour.
Step 2: Remove the Chip From the Immobilizer Box.
And then use programmer to read out the data and write the initial data into.Reinstall the immobilizer box on the Toyota Reiz.
Step 3: Programming Keys
Plug the first master key into the ignition,the immo light will light on.Then plug the next key into ignition,the immo light will off,and on again.And plug the third keys into ignition,the immo light will flash twice and then off.
Step 4: Synchronize Data for Immobilizer and Engine ECU
After programming,the keys you programmed still can not start the engine,because ECU has not been synchronized to immobilizer system.So now you need to perform engine ECU synchronization.Use a wire to connect 4th pin to 13th pin of OBD port.Then turn the ignition on,you will see two lights flashing on the dashboard.Then wait about 50 mins,then turn off ignition.
From Auto Repair Technician Home, post Toyota Reiz 2010 G Chip All Key Lost Programming
