Introduction: How to Fix a Leaking Hamilton Beach FlexBrew 49976
If your coffee maker pools water underneath after brewing the carafe side it's most likely a specific hose that gets loose where it connects to the spout on top. This will hopefully help you fix it.
The goal is to get the back off and you'll need a tri wing screwdriver to remove the bottom panel, the one I used was labeled size Y1. The rest are standard Philips head.
You can risk just reattaching the original clamp but I suggest using something more permanent like a hose clamp.
There are also other methods such as simply cutting a hole in the back where the hose is attached which may or may not be easier depending on the tools you have on hand. There's a YouTube video about this method.
Edit 6/30/20:
The coffee maker failed again after the 3rd time fixing this with the hose clamp so please manage your expectations. Ended up getting a Ninja that I'm very happy with, best of luck!
Step 1: The Bottom
On the bottom of the machine there are eight tri wing screws and only the middle back one is connected to the back panel, but to be able to pull the sides away it's easier to remove the whole bottom piece.
Step 2: The Sides
You'll need to pull the sides away from the back panel to expose 4 screws. There's 4 tabs on each to push in with a flathead that will allow it to pull away.
Step 3: The Back
Once the sides are away there's five screws to remove. Two at the top with the head facing down and two and the bottom facing the back. The last one is below the carafe flap at the top and requires removing the cover at its hinge, but be careful there's two little platic tabs that break pretty easily. Now the back can slide down and expose the problem.
The hose feeding hot water up to the top of the machine isn't attached correctly, the metal clamp it comes with doesn't do the job. The first two times I did this fix I used a zip tie in conjunction with the clamp but was still not enough. The latest time I used a 1/2" hose clamp which should be much more secure.
Hope this helps you!
16 Comments
1 year ago on Introduction
Thank you! The instructions and details were a huge help! We used your suggestion and used a 1/2 inch hose clamp to secure the hose. So fingers crossed this does the trick!
2 years ago on Introduction
Very helpful, I had this issue, fixed it, now it started leaking again this time it is the other hose the short one with the valve that prevents backflow is split in two, so now for the search for a replacement hose.
3 years ago on Step 3
3 years ago on Introduction
Thank you for letting me fix my leaky coffeemaker. It's only two years old and I wasn't looking forward to having to buy another. I didn't take the side all the way off, just made room enough to get to the screws. Also like KevinH444 I used a small flat head screwdriver on the tri-prongs. Yea! No more puddles.
Tip 3 years ago
Thanks ! Instructions were great - I am a little slow so the sides were a struggle - Just reread instructions carefully - I busted the "little tab" per your warning - didn't get the sides completely off, but enough to wiggle on the tube and clamp (Great Idea !) - Note: Use a small flat head for the Evil Tri-Prong Screws - got this idea somewhere else - Works ! Back to Mak'n Coffefe !
Question 4 years ago on Step 2
I have the bottom off but I'm stumped on the sides. Where are these 4 tabs?? The photos don't help...
Answer 3 years ago
The tabs are on the two side pieces. The video understates the difficulty of getting them loose. Start with the side piece that has the most flex at the top. I actually used a chisel instead of a wide flat blade screwdriver. Once you get the first one you can see better how to work your way along and get the rest. I like the idea of cutting a hole in the back instead of all this hassle. The bad hose connection is at the top just before the hot water goes into that piece that distributes it over the coffee grounds.
Question 3 years ago on Step 3
What size tri wing screwdriver do I need?
Answer 3 years ago
The one I used is labeled Y1 and resembles a standard Philips head but with three wings.
Nailed it!! Thank you so much!! And doggone if you weren’t right ... totally snapped that little plastic tab on the water reservoir flap! Oh well... coffee is brewing and that makes it worth it!!
4 years ago on Step 3
man was right hose clamp was loose put new clamp on
How do u get the sides off??
Answer 4 years ago
I did it!! Your instructions were exactly accurate. But, If this happens again I'm getting a new pot! Don't want to do that again. Lol
Answer 4 years ago
There's four little tabs on each side that you need to push into at the seam with something thin, I just used a really small flathead. With the bottom off you should be able to see the one near the bottom and the rest will be easier to see once one is out unclipped.
4 years ago on Introduction
Thank you so much for this! I was able to fix it using your instructions and I felt SO GOOD that I fixed it!!! I had quite a time finding the tri tip screwdriver I ended up getting it on Amazon because my local hardware stores didnt have one. It was just like what you described and so easy to fix!
4 years ago
Nice repair job. Sure beats buying a new one.
