Introduction: How to Make Milk Tea Boba
Today ill be showing you how to make milk tea boba. Boba is a drink with tapioca pearls with any type of tea. Boba is simple to make and it doesn't take too long. You can get your supplies at any local groceries stores. I'll be using British tea but any type of strong tea can work. You can use smoothies but it'll just be showing you milk tea boba.#HMS2020
- Water
- Pots and pans
- bowl
- Stove
- Boba straw
- Spoon
- A cup
- measuring cups
- Ice cubes
- Sugar
- Tea
- Tapioca Pearls
- Milk
Step 1: Preparing the Tapioca Pearls
Bring 8 cups of water to a boil in a deep pot. Then add 1 cup of black tapioca pearls. For every 1 cup of tapioca pearls, add 8 cups of water. Boil the tapioca pearls until it floats to the top then cook on medium heat for 2-3 minutes. Once you have finished boiling your tapioca pearls you scoop the tapioca pearls out of the pot and let it rest in cold water for 20 seconds. Then transfer it into another bowl.
Step 2: Preparing the Syrup
Grab a saucepan and add 2 cups of water until it starts to simmer. Once the water has simmered add 2 teaspoons of sugar. Mix the sugar around until it dissolves. After the sugar has dissolved turn off the stove and add your tapioca pearls into the syrup and mix it around.
Step 3: Making the Tea
You can use any type of strong tea or ice tea for your boba but ill be using British tea. My tea is hot tea but you can use ice tea. Grab your tea bag and place it into your cup and add 2 to 3 teaspoons of sugar. Boil half a cup of water and add it to your tea. Mix it around and take out the teabag. Add a fourth of a cup of milk in the tea and mix it around.
Step 4: Finishing Off the Boba
Once you have finished making your tea, add your tapioca pearls that are mixed with the syrup into your tea. Add as many ice cubes as you want. Then add your straw and mix the tea around with your tapioca and you're done!
Conclusion
Boba can use any tea and any brand of boba whichever works for you. Boba is an easy beverage to make and it doesn't take long. Do whatever works best for you. If you have different tapioca pearls still check the instructions on the back just to be sure you are boiling your tapioca pearls right.
