Introduction: How to Make Cupcakes With Cake Mix
I’ll be showing you how to make cupcakes with cake mix
Step 1: Put Cake Mix Into Bowl
The first step is to open the box and then place the cake mix into a large bowl
Step 2: Add Water
Next you will add 1 cup of water to the mix
Step 3: Add Vegetable Oil
After adding the water you will then add 1/3 cup of vegetable oil
Step 4: Add Eggs
After that you will then add 3 large eggs all of the egg (meaning the egg white and the yolk)
Step 5: Before Mixing
Before you mix everything together to make the batter this is what it should look like.
Step 6: After Mixing
Once you mix for ten minutes by hand (you can also use a mixer) then the batter should look like this and start to form.
Step 7: Line the Cupcake Pan
Once your batter is ready you can then put cupcake liners into the pan
Step 8: Pre-heating the Oven
While you put the batter into the cupcake pan you will then heat up the oven to 350 degrees Fahrenheit for 30 minutes
Step 9: Putting the Batter Into the Cupcake Liners
While the oven is pre-heating you then scoop 1 1/2 scoops of the batter into each cupcake liner using an ice cream scooper.
Step 10: Taking the Cupcakes Out the Oven
Once the cupcakes come out of the oven they should look like this if you want the cupcakes to be even you can cut of the tops like I did.
Step 11: Cooling Off
After cutting off the tops (if you chose too) you will let the cupcakes cool off for 30 minutes.
Step 12: Finishing the Cupcakes
Once the cupcakes are cooled you can frost them and add sprinkles if you like.
