How to Make Mountain Pies | Campfire Sandwiches
93,791
171
33
Introduction: How to Make Mountain Pies | Campfire Sandwiches
About: Designer. Thinker. Doer. Hiker. Lover.
Years before I had even heard of a panini, I was making mountain pies on camping trips. My family had two 'mountain pie makers' or irons and they were a staple for any vacation and often a part of summer bonfires in the backyard.
When we got married, I decided it was time for my own mountain pie maker and we registered for one. As we've used it on our own camping trips, I've been shocked to learn how few people know about this beautiful thing.
You can find the irons at camping and outdoor stores and they come in a variety of shapes. I prefer the square shape and the tapered sides. My mom swears by Old Mountain.
Mountain pies are great for a group camping trip because everyone can make their own sandwich. We had a great time on a bigger trip making it into a competition to see who could make the best combination. There were some stellar pies, including:
- Ham, swiss, and mustard (Bavarian Mt. Pie)
- PB&J
- Blueberry jam and marshmallow
- "S'mores" Mt. Pie (marshmallow and chocolate with bread)
- Blueberry jam, banana slices, chocolate, and granola
- Monterey jack + salsa
...but my favorite is the classic pizza with sauce, shredded cheese, and some cut up pepperoni slices. That's what I'll show here in this Instructable.
Step 1: Gather Your Ingredients
In addition to the mountain pie iron and a good fire with a lot of hot embers, you'll need:
- Bread (best is square slices instead of rectangular ones)
- Shredded mozzarella cheese
- Pizza sauce in a squeeze bottle (Yup, this is a thing!)
- Pepperoni slices, or whatever other 'toppings' you'd like. Just remember if they're meat toppings that they should be precooked and ready to use
Step 2: Prep Your Iron
Mountain pie irons are made of cast iron and follow all the same rules. Try not to wash with soap, don't worry about chucking it in the middle of the fire, and a lil' love from Pam will make everything go smoothly.
Give your iron a spray of Pam before laying down the bread and repeat this step between each mountain pie you make!
Step 3: Place the Bread
I recommend building up the entire sandwich on one side instead of a little on each and then trying to flip it over onto itself. It's just cleaner.
Also, be careful if you're not making the first mountain pie as the cast iron will be very, very hot. You should still be able to assemble your mountain pies on the iron itself, but if you have little ones helping to make these delicious creations be sure they understand not to touch the parts that just came out of the fire.
Step 4: Add Your Toppings
Place your topping in any order you'd like - it'll all get sealed up in a delicious pocket of campfirey goodness no matter how you do it.
A few suggestions:
- Be careful how much sauce, jam, or filling you add as that's the part that will likely come out as smoking hot lava. Less is more on this front.
- Try to keep your toppings centered in the middle of the slice of bread
- Things like pepperoni slices, apple slices, or pepper strips are good to cut up into even smaller pieces. It's not for when you are cooking but afterwards while you're taking hot bites of the gooey goodness that you'll thank me.
Try not to over-stuff your first few! You'll get the hang of it, but in the meantime you can always make another :-)
Step 5: Close 'er Up!
Take the other slice of bread and position it on top of your toppings and then close the iron together. Most new irons come with a clasp to keep it closed in the fire but somehow ours always seem to fall off. There's a little leather tie around the handles and that seems to be enough to do the trick while it's in the fire.
Oh, and don't worry about any bread that is poking out of the sides. It'll burn off or you can scrape it off while you're taking it out of the fire.
Step 6: Put It in the Fire
Place your closed mountain pie iron in the hottest part of the fire - ideally wedged in between some embers.
Every fire is different and so there's no perfect timing guideline. I recommend checking after the first minute, especially if you have a really hot fire, and look at both sides to see the color of the bread. You might need to flip the iron over and continue cooking on the other side if the top and bottom are receiving different amounts of heat.
Check the pies by pulling the entire iron out of the fire and lifting the top handle to check the bread. If it looks like the pie is stuck to the top side, close it, flip it over, and check the other side. It's helpful to have a fork or knife (not plastic!) on hand to help wriggle the mountain pie free, even after spraying it with Pam as the edges can hook onto the iron.
Again, the first mountain pie of the night will take longer to cook than the rest and the same is true if it's been a while since someone has made one. The heat of the fire will also change, so just keep an eye on your mountain pies while they're in the fire.
Step 7: Enjoy Your Moutain Pie
The insides will be hot if you did it right, so be careful as you eat!
If it's cool enough to handle, you can break off any burned bits and toss them back into the fire.
We've done this over campfires, in our backyard, in fireplaces, and with charcoal at a BBQ! All you need is a strong, hot heat source that can surround the mountain pie maker and you're in business.
I hope you make your own and if you do, please share your new flavor combinations in the comments below!
Great Outdoors Contest
Maker Family Contest
BBQ Contest
BBQ Contest
1 Person Made This Project!
  • Make It Bridge
    Make It Bridge
  • Big and Small Contest
  • For the Home Contest
33 Comments
ancienthart
ancienthart
3 years ago
Here in Australia, we call them Jaffles. You can even buy an electric version that you can use at home on the counter-top. If you use squares of puff pastry and squeeze the edges together really well, you can also make fruit pastries in them. (Canned apple, sugar, cinnamon)
caveman5375
caveman5375
7 years ago on Introduction
here in uk there called toasties, corn beef, cheese, jam
acoens
acoens
Now that I live in the UK, I'm a big fan of the toastie, caveman5375. It's no wonder - I've been training my whole life for this ;-)
Cintka1
Cintka1
8 years ago on Introduction
We call them Pudgy Pies, I love to make rueben pies , Kraut, corned beef , and swiss cheese!
acoens
acoens
Pudgy Pies! That's fantastic!
Your rueben pies sound delicious. Must try next time :-)
Porschephile
Porschephile
I just picked up one of the Rome's extra long double irons and took it camping last weekend - fantastic!
I had to spend 15 mins seasoning the iron in the fire but after that it was basically in use all weekend.
Even when you run out of bread it's like having two little skillets to cook in from the comfort of your chair. Great Ible, can't wait for next weekend now :)
You can also do tacos with tortillas and leftover taco meat/cheese etc.
acoens
acoens
Thanks for the kind words, Porschephile! Taco mountain pies would be delicious :-)
ijtw69
ijtw69
We've cooked hamburgers with our mountain pie makers too. No bread. a thin hamburger patty, slice of onion, and another thin patty. Cook each side for 2 or 3 minutes and check for doness. I also made breakfast by breaking up sausage and some tater tots; Cook until done, then add an egg or two. Your only limit is your imagination...
acoens
acoens
I love these suggestions!
Just as a caution, though this might not matter in your case: If you're cooking meat directly on the cast iron, you just need to be careful to warn any non-meat eaters before they have future mountain pies as the fats and oils may linger. Some people are more sensitive to it than others.
ijtw69
ijtw69
8 years ago on Step 7
When we make mountains pies; we like to lightly butter the outside bread. This helps it not to stick and makes it a nice golden brown. Putting the pizza sauce in a condiment/squeeze bottle makes it a lot less messy.
acoens
acoens
Ah yes, butter or a spray oil like PAM definitely help to release the bread!
And I completely agree about the squeeze bottle :-) I make my own sauce for regular kitchen cooking for the rest of the year but usually cheat and get the Contadina pizza squeeze sauce for camping and mountain pies.
Bubbler
Bubbler
Winter has just begun where I am, and this post has reminded me to get cracking on a camp fire in the yard. I have the same style iron as yours, but only I have two of the double irons. This means I can get two pies going in the fire, and then turn to the other double iron, and set up two more pies. It helps with the craving the crowd seem to get. Haahaa.
acoens
acoens
Sounds like you have an assembly line going! That's terrific.
lstephens6
lstephens6
8 years ago
Seasoned Pulled pork and provolone.
acoens
acoens
Oh goodness, that sounds awesome! I bet some hot peppers (banana or jalapeno) would be excellent with pulled pork and provolone, too.
parcord
parcord
8 years ago
I tried peprer jack and salsa and it is good to
acoens
acoens
Oh, good combo! If you eat meat, that would be delicious with some pre-cooked chicken.
matthewabel
matthewabel
We have a double-sized one that doubles as a hot dog cooker. Cast iron ones - the aluminum ones have worn out far too quickly for our needs. These are terrific and fun for the kiddos.
acoens
acoens
Cast iron is the way to go! I loved making these as a kid and they're just as fun now :-)
Lightningdog2013
Lightningdog2013
8 years ago
Hobo pies here in Michigan. We mix cream cheese and sugar for a sauce and then add cherry or apple pie filling.
