How to Make a Kubb Set
470,627
294
63
Introduction: How to Make a Kubb Set
About: I like to make things for the internets. I also sell a pretty cool calendar at supamoto.co. You'll like it.
One of the best things about summer is playing a casual game on a field or the beach. In our office, one of our favorite games is called Kubb (rhymes with "tube") that is originally from Sweden. If you have access to some woodworking tools it's pretty easy to make and a lot of fun to play.
What's so fun about the game may not be obvious at first, but after a single game many people get hooked. Trust me, it's worth the bit of effort it takes to make a set.
Kubb wiki page
Rules of play
Step 1: Get Some Wood!
To make one set you'll need:
- 6' of 4x4
- 6' of 1.5"-2" dowel
- 4' of .75" dowel
- 30' of string
If this is your first set you might want to pick up an 8' piece of 4x4 to try making a couple different kings.
Step 2: Make Your King
Chop off 12" of the 4x4. This is the wood for the king which acts like the eight ball in the game of Kubb. Knock it over at the end to win, but if you knock it over early you lose. Either way it only gets hit once per game and it often gets decorated to show off how important it is.
The amount of decoration is up to you. All I used for these two kings was a table saw. Two 45-degree cuts were used to notch the sides and a series of cuts decorated the top. A router would work brilliantly here as well.
Or don't cut it at all and draw a smiley face on it. It's up to you.
Step 3: Trim the Rest of the Wood
The rest of the pieces, the kubbs, are narrower than the king so you'll need a table saw to cut them down.
The size of the kubb is 7cm x 7cm x 15cm or 2.75" x 2.75" x 5.9" so trim off .75" off of two sides of the 4x4.
Step 4: Chop Off the Kubbs
Now that you have the right size wood, just chop off 10 5.9" lengths of it and you have your 10 kubbs.
Step 5: Chop Up the Dowels
You want 6 batons to throw at the kubbs and the king and these should be about 12" long. You also want 4 stakes to mark off the playing field and these should be about 12" long as well.
So chop off 12" lengths of both size dowel.
Step 6: Knot Up String and Wrap Around a Stake
The playing field for kubb is 5m by 8m or roughly 16.5' by 26'. You can mark this off with strides or you can get a length of string or rope and tie a few knots in it so you can quickly mark off your playing field accurately.
Below you can see one of the stakes wrapped with a knotted piece of nylon rope.
Step 7: Get Out and Play!
Now that you have a set, you should go out and play with it! It's awesome and you can work on your throwing skills.
Below, Bilal throws for guts and glory.
Again, for the rules, check outthis link.
5 People Made This Project!
  • Eggs Challenge
    Eggs Challenge
  • Remote Control Contest
  • Backyard Contest
    Backyard Contest
63 Comments
Raleigh Flowers
Raleigh Flowers
3 years ago
Thanks for the information and links. I condensed the information down to one page of build instructions and rules. Hope it helps.
pcmusich
pcmusich
Reply 1 year ago
THANK YOU!!!!
gdsmit1
gdsmit1
5 years ago
Looks fun. Might give this a shot.
BTW, the links to the PDF of the rules is broken.
Arrhyno
Arrhyno
9 years ago on Introduction
Don't want to be too over-the-top when I play, but as a noob (pronounced like newb), would the extra weight of treated 4 x 4's (which I have some scraps of) throw off the way the game is played? Can any experienced players let me know what they think? Thx
ducksarewet
ducksarewet
As someone who has played, I don't think it would be noticeable.. However, I wouldn't use pressure treated (PT) lumber unless people can wash their hands after. PT has toxins which transfer to skin. This isn't good if you are playing at a BBQ picnic.
AmluxGaming
AmluxGaming
Reply 5 years ago
If you coat it with some lacquer it should be fine then.
voltan
voltan
6 years ago
Is there something interesting that could be done with the "L" shaped peices?
TheLazyCrafter
TheLazyCrafter
6 years ago
Well, I was advised to not use my table saw to rip the 4x4, so I did two cuts with the circ saw and then after cutting the Kubbs to size I evened them out with the miter. My teenage daughter taught me about this game because she plays it in gym class. Sounded like fun, but there is no way I'm going to pay $100+ for it when it's so easily made. I used untreated Douglas Fir for the 4x . Thank you for the plans!
kamazeuci
kamazeuci
13 years ago on Step 1
I think you really don't need the exact measures. For example, I've just made my kubb set with firewood splitted with my axe. I did the best to match indicated sizes but obviously with an axe you can't be that precise.. I bet vikings didn't buy their kubbs at home depot.
SkandoFlambo
SkandoFlambo
No they sure didn't, but they were probably more accurate with an ax then they would be with a circular saw.
ArtisanEclectic
ArtisanEclectic
Reply 6 years ago
With both tools the main concern is finishing with the same number of fingers as you started with!
Fly4aWhiteGuy
Fly4aWhiteGuy
7 years ago
For the pronunciation freaks... Did it occur to you that pronunciation variations could be regional?
HewgO
HewgO
14 years ago on Introduction
Great Instructable! However, "Kubb" doesn't rhyme with "tube", it actually rhymes more with "tub". Trust me, I'm from Sweden :P Anyways, it's really fun to see that people outside of Sweden are taking a liking to this fantastic, wood-tossing, game :)
Eric95
Eric95
Reply 12 years ago on Introduction
It's not pronounced koob! HewgO is right, it rhymes more with tub, but the U sound is like a mix between the american U and O.
Eric95
Eric95
Yes! Are you swedish? I am. It's pronounced more tike tub than tube.
SkandoFlambo
SkandoFlambo
Jo jag föddes I mora och min mor lär Amerikaner Svenska. I am Swedish, and my mother teaches Swedish to American/w.e culture adults. Not that it really matters, but it is much closer to toob, then tub.
HewgO
HewgO
Yes.
"Koob" is actually a very good example of how it sounds like when americans try to speak swedish. They never quite get the U right.
