Introduction: How to Make a Small Desk Clock With Weather Station
Hi beloved readers in this project I will show you how to make this Small Desk Clock with Weather Station
This is a step-by-step article, I will guide you through the process of creating your very own desk clock using a Mini LCD display, Wemos D1 Mini microcontroller, lithium-ion battery, and the ability to show real-time weather and temperature data.
This project combines electronics, programming, and creativity to build a unique and functional desk accessory
What can you expect by building this project?
There are many things but most importantly you will have a desk clock that shows you the real-time temperature, Day, Date, and time.
Along with this, you will learn lots of things like how to make connections and the basics of electronics and programming..
Below are the components required for making this desk clock
- Wemos D1 Mini ( Amazon /AliEexpress)
- 1.54inch LCD Module 240x240 display module ( Amazon /AliEexpress)
- Breadboard ( Amazon /AliEexpress)
- Charging Module(Type C) ( Amazon /AliEexpress)
- Battery ( Amazon /AliEexpress)
Tools Used:
Soldering Iron ( Amazon /AliEexpress)
3D printer ( Amazon /AliEexpress)
- Arduino IDE and Programming cable ( Amazon /AliEexpress)
Step 1: Circuit Diagram
The circuit is very simple for this project
So we will begin with connecting 1.54 inch LCD module to wemos d1 Mini.
5 volt of wemos d1 Mini will be connected with vcc of LCD module, g to gnd of LCD module,d4 to RST, D2 to DC, D8 tp CS, D7 to Din and clk to D5
This is the connections, and i know you are thinking it is very simple, Indeed it is simple
Step 2: Building Circuit
I will be using Breadboard and jumper wires to make the prototype circuit.
Start by attaching wemos module to the breadboard, and later connect the display module using jumper wires.
To power this project I will be using a rechargeable lithium-ion battery.
After the circuit is complete we can head over to uploading the codes for this clock.
Step 3: Arduino Code
Setting up the Arduino IDE
If you don't have IDE. Download and install the Arduino IDE from the official Arduino website (https://www.arduino.cc/en/software).
Connect the Wemos D1 Mini microcontroller to your computer using the USB cable.
Opening the Arduino Sketch
- Open the Arduino IDE. You can get the Arduino code for this project here https://bit.ly/3qe1FI5
- In the IDE, go to File -> Open and locate the Arduino sketch (code) file for your desk clock project. Open the file in the IDE.
- From the "Tools" menu, select "Board" and then choose "Wemos D1 R1" or "Wemos D1 R2 & mini" as the board.
- Next, go to "Tools" -> "Port" and select the appropriate COM port that corresponds to your Wemos D1 Mini.
- Change the Wi-Fi credentials
- Click on the "Verify" button (checkmark icon) to compile the code. Make sure there are no errors or warnings displayed in the console.
- Once the code has compiled successfully, click on the "Upload" button (arrow icon) to upload the code to the Wemos D1 Mini microcontroller.
- The IDE will display the upload progress, and once complete, you should see "Done uploading" in the console.
Now you can see the display on and directly connect to your wifi, in a few seconds your clock will show the data
Step 4: STL and Gerber Files
As you can see since I used a breadboard to build the circuit, the project is large, If you don’t want to assemble the circuit on a zero PCB or a breadboard and you want PCB for the project, then here is the PCB for you. I used EasyEDA to draw the schematic first.
I want to shrink this project to a small size, so I made a PCB for this.
You can directly use my Gerber files, or create your own.
I have drawn the schematic by using EasyEDA online software and then designed a custom PCB for this project. I ordered my PCB from PCBWay and received it within 7 days.
Gerber File, Codes: https://bit.ly/3qe1FI5
You can use this Gerber file to order high-quality PCB for this project. To do that visit the PCBwayofficial website by clicking here: https://www.pcbway.com/
Why PCBway
- Most Efficient, Economic, Innovative PCB Solutions
- Higher Quality
- Lower Cost
- Faster Delivery
And for the enclosure, i used 3D-printed parts, you can use my stls here
Note that if you are using the same parts as I did, directly use my files for 3d printing
Step 5: Custom PCB
I got my custom-made PCB, and they were of very high quality.
Now the circuit becomes very very small.
All you need is just to solder the components to the PCB.
I soldered the Battery charging module first, later i soldered Wemos board
LCD can be attached later after we encase these first in the 3D-printed case.
Step 6: Casing
Luckily all the parts fit very well on my 3D-printed case.
Starting by adding the LCD display board to the case, I used tiny pieces of double-sided tape upon which I placed the battery, later I soldered the switch to the base of the box.
The battery was soldered directly to the PCB.
Now you can merge the case and couple ut with the screws, note that i dint exactly know the size of the screw, but you can use any tiny short screws.
Step 7: Finishing
After the case is finally finished all you need to do is press the switch.
As soon as you do it, LCD will on showing a connecting symbol
As it connects you can directly see the clock.
You can see date, day, time and weather stats.
You can place this tiny little clock on your favorite places!
This completes this project, if you have any questions you can ask me in the comments.
Step 8: Working Video and Tutorial
Here is the working video of this project, if you want a video tutorial on how to build this clock, just watch this video, I have provided all the details.
Hope you will enjoy making this desk clock project, Thank you for reading
