Introduction: How to Make a Thermometer Using Arduino and LM35
Today I am going to show you How to make a Thermometer with Arduino and LM35 temperature sensor,LCD Display,On a breadboard connected together with wires.It will show temperature in Celsius and Fahrenheit.
We Observed
Step 1: Requirements:-
This is the list of parts needed to make the thermometer.
1.1 x Arduino UNO board
2.1 x LM35 temperature sensor
3.1 x LCD Display (16A1,16A2 or any other)
4.1 x Breadboard
5.1 x 10k Potentiometer/variable resistors(You can also use 5k or 50k)
6.Some male to male jumper wires.
7.Power Bank or Battery
*.Arduino IDE installed in pc with some basicinformation about how to use it.
Step 2: Basic Information About Parts and Links to Buy -
Step 3: Pin Diagram of LM35
Pin diagram of LM35
Step 4: Circuit Diagram
There Are no difference between 16 x 1 and 16 x 2 display's pins so Just follow the circuit and use power bank to give power to completed project.The circuit is very easy and the assembly/connection is also very easy just use the above circuit diagram and make all the connection carefully .Now connect the arduino board to the pc and upload the below code.
Note:-
I am having an old 16 x 1 lcd display(JHD16A1) so i used it in this project,But In this project any display will work.and16x2 is better so i am giving link for 16A2 display link.You just have to change some code i explained everything in coding part.
Step 5: Coding
//By SOURABH KUMAR @ weobserved.com
#include
LiquidCrystal lcd(12,11,5,4,3,2);//pins diclaration for lcd on arduino
const int inPin = A0; //Middle (Output) pin of LM35
void setup()
lcd.begin(8,2); //Change here accoring to your lcd
void loop()
int value = analogRead(inPin);
lcd.setCursor(0,0); //No change
float millivolts = (value / 1024.0) *5000;
float celsius = millivolts / 10;
lcd.clear();
lcd.print(celsius);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print((celsius * 9)/5 + 32);
lcd.print("F");
delay(1000);
Above is the basic code for The thermometer
Note-
As i said i am using an old 16x1 lcd which only works correctly when it will be assumed and deaclered as 8x2 lcd.But when you will use16x2 display then this problem will not accure.for 16x2 display just find
in the code and replace (8,2) according to your display as(column,row) .let you have a 16x2 display then replace (8,2)with (16,2).and if you have 20x4 display just replace the (8,2) with (20,4).
Download the .ino file from here
Step 6: Everything Done Time to Enjoy
How To Make a Thermometer using Arduino and LM35
After uploading is finished instantly the thermometer will begin to work if nothing visible on lcd other then just bright yellow light then just adjust the back-light through the 10k Potentiometer/variable resistors.After adjusting you will find the output as shown in figure below.Finally we have made a thermometer using Arduino and LM35 which is able to show temperature in Celsius and Fahrenheit You can modify codes and also circuit according to you. So i hope you will like this easy project.
ThankYou
Please visit
We Observed
Sensors Contest 2016
Question 4 years ago on Step 5
In the code why devide by 1024 and multiply by 5000
