Introduction: How to Transfer IPhone Contacts to PC/Mac and Restore Back to Your Device
Did you ever wonder how to transfer or backup iPhone contacts to your PC/Mac and restore them back to your device?
The iPhone is not really like other smart phones. While that is part of the reason why so many individuals are drawn to it, being different is not always a good thing. For example, unlike the Android, the iPhone does not allow its users to back up their contact files on their SIM card. The unfortunate truth is that Apple wants uses to rely on iTunes to back up all of the information on their iPhone. Wouldn't it be nice if there was a way to back up the contact files on your iPhone to your PC/Mac without having to use iTunes? Fortunately, there is.
iPhone Contact to Computer Transfer (iPhone Contacts Backup) is the name of a program that all iPhone users need to have on their computer. This is because for most iPhone users, their contact list is one of the most important parts of their iPhone. Naturally, this makes it a very important part of the iPhone to back up. Trying to rebuild a contact list from scratch is not an easy task for anyone. For that reason, this program is the key to making sure you are never stuck in a difficult situation again.
Step 1: Download, Install and Launch the Program
Figuring out how to transfer your iPhone Contacts to your PC or Mac computer as well as transferring them back to your iPhone is a process that is broken up into several small steps. Keep in mind, you are going to need to download, install, and execute the program. To get more information and to download the program for both Mac and Windows, you may visit this website
Then, you need to connect your iPhone (or other Apple device such as iPad or iPod) to your computer. You will know if the program works correctly because it should automatically recognize your iPhone.
Step 2: Backing Up Your IPhone Contacts to PC/Mac
Once you launch the program and connect your iPhone to the PC/Mac. Wait a few seconds for your iPhone address book to appear in the programs interface.
In order to backup your iPhone contacts you are going to start by selecting the option labeled "Contacts" in the left panel. Then, you just need to select the contacts you want to transfer. Finally, you just have to click the button labeled "Back Up All Contacts" that is located at the bottom of the screen.
Step 3: Transfer Contacts From Your IPhone to PC/Mac
Fortunately, this program was created to make it easy for the user to export contacts to their computer/Mac as well. You are more or less going to be repeating the process of step two. You are going to click the option labeled "Contacts" and select the contacts you want to export by checking the boxes next to them. Once you have made your selections, you will click the button labeled "Export Contacts to Computer." You can export iPhone contacts to your PC/Mac as a .csv and .vCard file format.
Step 4: Import Contacts to Your IPhone
Lastly, this program was also design to be capable of importing contacts back to your iPhone after they have been stored on your PC/Mac for safekeeping. Fortunately, step three is exactly like step one and two. You are going to start out by selecting the option labeled "Contacts" in the left panel. Then, you will need to select the contacts you want to import. Once you have made all of your selections, you will click a button at the bottom of the interface that is labeled "Important Contacts to Device.”
Step 5: Restoring Contacts Back to Your IPhone
Individuals can use the restoration function of this application to restore iPhone contacts to their iPhone. Under the left panel that they have been using, there should be a second one labeled "Backup Files." All an individual has to do is select the option labeled "Contacts" and select which backup file they want to restore. Finally, you just have to press the button labeled "Restore all Contacts to Device" which is located at the button of the screen. This will initiate the restoration process.
Step 6: Summary
Should you ever suffer the misfortunate of losing your iPhone, iPhone Contact to Computer Transfer is a program that you will be glad you took the time to install. This application gives iPhone users a sense of security in knowing that all of their precious contact files have been safely secured on their PC/Mac in the event that they should lose access to them from their iPhone.
In short, it is a must-have program to transfer or backup contacts from your iPhone to PC/Mac and manage them with ease.
13 Comments
5 years ago
To transfer iPhone contacts to PC/Mac, you can try iPhone Transfer. It can help you a lot. When it comes to restore data back to your device, you can give iPhone Data Recovery tool a try. It provides there ways to recover data and will never let you down.
5 years ago
Recommend you the FonePaw iOS Transfer which can transfer files between iOS devices and PC/Mac. It supports to transfer songs, contacts, photos, call logs etc. Of course, you can transfer contacts from iPhone to computer selectively without iTunes.
5 years ago
The program has not updated for years and not support the latest iOS. I suggest to give it a on this amazing software instead: http://www.imoresoft.com/phone-transfer.html
You can backup, restore and transfer data freely between different devices.
5 years ago
Thanks for sharing, but I prefer Apowersoft Phone Manager to transfer and back up my iPhone contacts. It can transfer contacts to PC as well as put them back to the phone. And it is a multi-functional tool which I like most, I can use it manage my contacts and other files too.
5 years ago
I want to recommend you an useful and convenient way to transfer contacts from iPhone to PC/Mac. Try iPhone Transfer, which is a powerful data managing software that can not only simply sync the contacts from iPhone to PC/Mac, but also save them on your PC/Macbook as the format you like, CSV files, vCard, and so on. Last but not least, you can merge the duplicated contacts with one click.
Reply 5 years ago
Here you can try iPhone Transfer after you click the link below.
https://www.recovery-android.com/iphone-transfer.h...
6 years ago
Phone Transfer is a pretty nice program to move data between smartphone and computer, including iPhone, Android and Windows phone. It has a great user interface and easy-to-use instructions. Here is a demo for Android (also applies to iPhone): http://www.imoresoft.com/phone-transfer.html#part3
6 years ago
Have a look at this tutorial, which is the simplest way to transfer contacts back to computer. You can also use the program for data backup.
Tutorial: How to Transfer iPhone Contacts to Computer
6 years ago on Introduction
I found this very helpful. I was trying to backup/transfer contacts of my old iPhone (iPhone 3GS) to my Windows 10 computer so that I can restore them on my new iPhone 6. But unfortunately, icloud wasn't working with this because it's an old ios device. Additionaly, I used it to create a backup of my iPhone 6 contacts too. Amanda-t, kudos to you!
7 years ago on Introduction
Please correct the article. A PC (p.c.) is a personal computer e.g. Apple Macintosh.
The article title should read: How to Transfer iPhone Contacts to Windows/OS X and Restore Back to Your Device.
Before a sync or restore, I believe that iTunes will create a backup of your phone's contents (unless you manually cancel this backup). The backup will contain the photos and videos that were on the phone.
You can check if a backup was created by doing the following:
Launch iTunes
iTunes > Preferences > Devices
See if there is an entry with the date of the restore.
If a backup exists, you can restore contacts on iPhone with one of two methods:
Restore your phone using that backup; or
Use an application such as iPhone Data Recovery to extract the contacts out of the backup file.
Use your Mac Address Book and sync your iPhone with iTunes. From the Info tab, under Contacts, make sure to select “Address Book” from the drop-down menu before you sync.
I am not sure whether it works on Mac, but you can use copytrans contacts to transfer the contacts too (in case you do not want to use iTunes sync):
http://www.video-converter-mac.org/iphone-contact-to-mac-transfer/
Finally, you can simply use the iCloud app and install it on your Mac. Make sure to enable iCloud contact sync on your iPhone. Then import contacts from your Mac to your iCloud application, this will move and sync the contact entries to your iPhone.
8 years ago on Introduction
Impressive! Yesterday,I failed to transfer my iPhone contacts to PC via iTunes and I couldn't figure out what the problem was.Now I will try this transfer tool!
