Introduction: How to Use BMP180 With SkiiiD
A tutorial to develop BMP180 via "skiiiD."
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Search or Find a Component
① Type 'BMP' on the search bar or find the BMP180 on the list.
Step 5: Select BMP180
② Select BMP180 Module
Step 6: Pin Indication and Configuration
then you can see ③ pin indication. (You can configure it.)
*This module has 4 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for BMP180 Module] in case of Arduino UNO
5V: 3.3V
GND: GND
SCL: A5
SDA: A4
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of BMP180 Module
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
getPressure()
"Method that allows identifying current absolute or relative pressure.
If set mode as 0, return relative pressure value.
If set mode as 1, return relative pressure value.
The default of mode is 0."
getTemperature()
"Method that allows identifying current Celsius, Fahrenheit, or Absolute temperature.
If set mode as 0, return Celsius temperature value.
If set mode as 1, return Fahrenheit temperature value.
If set mode as 2, return Absolute temperature value.
getAltitude()
"Method that allows converting altitude value to meter or feet unit.
If set mode as 0, return altitude value to meter.
If set mode as 1, return altitude value to feet.
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and feedback us, please. Below is contact methods
email: contact@skiiid.io
twitter: https://twitter.com/skiiiD_official
Youtube: https://www.youtube.com/channel/UCfS2RQL3m3hVoHkFo...
