Introduction: How to Use PressureSensor With SkiiiD
This project is an instruction of "how to use Segment 3642BH with Arduino via skiiiD
Before start, below is a basic tutorial for how to use skiiiD https://www.instructables.com/id/Getting-Started-With-SkiiiD-Editor/
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Search or Find a Component
① Type 'pressure' on the search bar or find the PressureSensor on the list.
Step 5: Select PressureSensor
② Select PressureSensor Module
Step 6: Pin Indication and Configuration
then you can see ③ pin indication. (You can configure it.)
*This module has 2 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for PressureSensor Module] in case of Arduino UNO
SIG: A0
VCC: 5V
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of PressureSensor Module
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
getData()
"Return ADC value."
isPressed()
"If pressure sensor is pressed return 1, else return 0."
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and feedback us, please. Below is contact methods
email: contact@skiiid.io
twitter: https://twitter.com/skiiiD_official
Youtube: https://www.youtube.com/channel/UCfS2RQL3m3hVoHkFo...
