Introduction: How to Use a Light Dependent Resistor (LDR)
Lots of projects use a Light Dependent Resistor (LDR) to sense light levels but don't really focus on how they work.
This project shows you how to use a Light Dependent Resistor (LDR) to sense light levels, measure those levels with the Arduino and print the measurements to the Serial port.
Arduino measures Voltages on pins A0 to A5; but the LDR is a variable resistor (varying with Light). So we need to convert the varying resistance to a voltage that the Arduino can measure.
We do that by using the LDR and a Resistor in a Potential Divider circuit.
By the way. If you like this Instructable, you might also like to read My Blog covering various projects and Tutorials.
Step 1: How It Works
The top of the Potential Divider is 5V; the bottom is at 0V and the middle (connected to A0) is some value between 5V and 0V that varies as the LDR resistance varies according to the light level.
As both resistors are in series the same current must flow through them both. The LDR resistance drops with light, which causes the current in both resistors to increase (I=V/R), and therefore the voltage across the other (non-LDR) increases.
So as the LDR resistance varies with Light, the Voltage at A0 will too.
Technically you can work out the Voltage on A0 as :
Va0 = 5 * R1/(R1+R2)
where Va0 is the voltage at A0 pin, R2 is the top resistor value, R1 is the bottom resistor value;
e.g. R1 = 10k, R2 = 5k => Va0 = 5 * 10000/(10000 + 5000) = 5 * 10/15 = 3.33V
The LDR has a high value when no light is present. The value of resistance of the LDR depends on the type. In this case it's about 10k. As the light level increases the resistance drops, which makes the current increase (by Ohm's Law), which in turn, makes the voltage at A0 (Va0) increase.
Electrically this is what's happening (skip this if you're not interested in this): The LDR and resistor are in series with the applied voltage (5V), so the current flowing through them is the same (the A0 pin draws virtually zero current). So the current through the resistor is (by Ohm's Law):
I = 5 / (R1+R2)
Now, the voltage across the resistor is applied to A0. Again, by Ohm's Law that is:
Va0 = I * R1
Substituting the equation for I back in to this equation we get:
See what it looks like on a Breadboard.
Step 2: The Code
You can use the AnalogInOutSerial code (File -> Examples -> Analog -> AnalogInOutSerial) to measure a value on A0 and print it to the Serial Monitor.
Step 3: How to Make It Better
- The AnalogInOutSerial code also uses the measured sensor value to change the brightness of an LED on pin 9. Add the LED.
- Make an Arduino Light Sensitive Bar Graph.
- Graph the light readings on your PC. See How to Send Data from Arduino to a PC
1 Person Made This Project!
- tanbirsohail made it!
32 Comments
Question 2 months ago
Je veux réaliser un système de mesure de luminosité ambiante est-ce que vous pouvez me sauver
LDR
Arduino UNO
Afficheur LCD
Battry
4 years ago
Can you tell me what is the analog output obtained by the LDR module? The unit of the quantity obtained as the analog output visible in the serial monitor of the Arduino
5 years ago
what is the role of resistor ? how i can select it ? why 10k ?
Reply 5 years ago
Because it's about the same value as the LDR's resistance. See my description about how it works.
5 years ago
i need a cood
5 years ago
i made my ldr project but values are fructuating in a constant condition can anyone tell me why?
6 years ago on Introduction
someone have an idea using ldr measure the angle of sun, display in 7 segment
Reply 5 years ago
I would imagine you could use multiple ldr's (inside varying lengths of tube, mentioned above) at different permanent angles, and check the amount of light (voltage to ldr) at the different sun positions if you kept the device in a fixed location. Or also if you didn't use multiple ldr, you could use one tube, and pre messure the light amounts during different angles of sun, and reference those values in your code. I guess it would work more like a digital sundial, but for sun angle. I think a device that actually determined the sun's angle at random geographic locations would have a lot more brainstorming...
Reply 6 years ago
it's not that easy. ldr only measure the power of light , not the angle to sun.
6 years ago
Hello,
Why do you need to connect a resistor to the LDR? Can you connect it directly between +5v and A0 without the resistors?
Reply 6 years ago
Hi tanmay, you need the resistor in order to create a so-called voltage divider. Basically you are turning the varying resistance of the LDR into a varying voltage at the midpoint (between the LDR and the resistor). This can then be easily measured by any ADC (Analog to digital converter).
If you don't put a resistor to ground and connect it directly between +5V and A0 then the ADC will not measure anything that is related to the LDR's resistance. All that's happening is a varying current enters the A0 pin which can not be measured like this. ADCs can only measure voltages directly.
Reply 5 years ago
Good answer. Now it makes sense. Thanks.
Reply 5 years ago
"The top of the Potential Divider is 5V; the bottom is at 0V and the
the LDR resistance varies. Remember the LDR resistance varies with Light
so the Voltage at A0 will too."
-The article already states that as the LDR resistance varies, the voltage at A0 will vary too. If the voltage already varies with the varying resistance of the LDR, why do we need the 2nd resistor to vary the voltage if that's already happening without it??
Reply 5 years ago
Both reistors are required to make the voltage change. Read on to this section which explains what's going on:
"As the light level increases the resistance drops, which makes the
(Va0) increase."
Reply 5 years ago
Thanks! I sent you a longer private message in response.
Reply 5 years ago
Reply 5 years ago
6 years ago
hy.plz tell me how to shield LDR from stray light.i am working on burglar alarm using LDR and lazer...i want to make ldr operative just with lazer light.plz plz reply me soon
Reply 6 years ago
Put the LDR in a tube. The tube will shield the LDR from stray light so only the laser light will fall on it. SImple as that :-)
6 years ago
hey how do you use an ldr to create a robot that can follow light
