Introduction: How to Use a Steamer on Clothing
· Begin by hanging the clothing where it is easily accessible
· Make sure the fabric you are steaming won’t melt such as suede or plastic
Step 1: Getting Prepared
· Check that the steamer is plugged in and filled up to the max line with purified water
· Once plugged in and turned on, allow the steamer to heat up until the water is boiling or steam begins to form
· Once boiling, you’re ready to begin steaming
Step 2: Steaming the Clothing
· Delicate fabrics can be damaged, to avoid this keep the steamer a few inches away from the garment
· Run steamer in a downward motion
· Continue this step until wrinkles are gone
· For heavy wrinkles steam from inside the garment
· After steaming, allow 5-10 minutes for the garment to sit and dry before hanging up or wearing.
· Unplug steamer and empty any remaining water inside. Replace the old water with new water.
· Shake the steamer gently to remove any mineral build and empty it again
· Leaving any water in the steamer could lead to mold build-up
