Introduction: How to Convert a Plain G-Shock DW-5600 to a Negative Display
This project was a little more adventurous for me and as you will see quite a bit more complicated than some of the other projects I've done with my G-Shocks. It involves doing some pretty nasty things to the screen of a G-Shock, so if you're faint hearted this is probably not the ideal DIY project for you. If you're still reading this and, like me, desperately want to try reversing the display of one of your digital watches - read on.
I'm going to be taking my plain DW-5600 and 'hopefully' converting the regular display into a negative one with the use of some self-adhesive polarizing film. There have been many questions about where to buy this posted in the various online forums. I bought mine from Polarization.com in Texas. The quality was very good, service excellent, and the shipping was pretty fast (3 days). I ordered the thinnest self-adhesive film they had in a relatively small size, the part name was: Linear Polarizer w/adhesive PFA.
Step 1: Tools Needed
- Plastic tweezers
- Spring bar removal tool
- Small flat head screwdriver
- Some Q-Tips
- A surgical scalpel or sharp modeling knife and fresh blades
- The all important Husky mini screwdriver (a must have item)
Step 2: Removing the Watch Straps
Take off the straps so that you can remove the back cover and so that they won't get in the way while you are working on the body of the watch. I like to use my nifty little Bergeon spring bar tool that is designed specifically for this.
Step 3: Removing the Case Back and Linings
Next, carefully remove the four small screws that hold on the case back. Always make sure to put these somewhere safe and keep them together. This is where the Husky mini screwdriver comes in very handy.
Remove the metal case back carefully, trying not to disturb the rubber gasket that creates the watertight seal around the module.
You should see the rubber spacer that covers and adds protection to the inner module. Remove the rubber spacer using the tweezers for extra grip. It can sometimes feel like it is deliberately stuck to the module but it isn't, it just gets pressed tightly and sticks a bit - it should come off very easily.
Step 4: Taking Out the Module
You should now be able to lift out the entire module by one of its edges using your tweezers. Mine actually fell right out when I flipped it over. Be patient, there's really nothing holding it in other than the pressure of the buttons against the spring contacts.
I took off on a bit of a tangent here and decided to remove the black outer rubber protector and the metal inner ring casing. I also removed the glass screen from the module and spent the next three hours shouting and cursing at how hard it was to put the darn glass screen back in. I was also extremely annoyed at my stupidity as I discovered that it was not necessary to remove the glass at all (I learn as I go along..). I have deliberately omitted the next six or so images that I took of me removing the glass and putting it back in because it is not necessary and very nearly screwed up my display and module!
Step 5: Removing the Factory Polarizing Film
The next thing to do is to remove the polarizing film that is glued to the surface of the glass. The film is slightly smaller than the glass and can be seen easily if you look close up. I am using my scalpel to gently lift up the polarizing film a bit at a time. The trick is to slide the blade between the polarizing film and the glass.
Take your time and work from one edge of the polarizing film across to the other, slowly pushing the blade of your knife under more and more while still moving it from side to side. Eventually you will have the blade under far enough to lift off the polarizing film.
The film is stuck to the glass by a thin layer of tacky glue. It's pretty nasty stuff so be patient and it will come up eventually. Lift off the polarizing film using your plastic tweezers. You can see that the film looks almost transparent while over the display and the digits are only visible on the parts of the display that are covered by the film - it's quite amazing.
Here's where it gets very cool. Simply turn the polarizing film around 90 degrees and as if by magic the digital display becomes reversed! The polarizing film does not need to be in contact with the glass to work.
Step 6: Testing the New Piece of Polarizing Film
At this point I used my Q-Tips and some Goof Off to clean the tacky glue residue from the glass and the old piece of polarizing film. Make sure you get the glass as squeaky clean as you can. It took me several Q-Tips and about 15 minutes to get it perfectly clean. I promise you that the time spent getting the glue off as much as possible will be worth it. If there is any glue residue left on the glass it will show up when you stick on the new piece of polarizing film and you don't want that.
Now let's take a look at the digital module display using the new sheet of polarizing film. Here is the display with the film held in the regular position. The display is shown as normal and we can see the module is still ticking away quite happily.
Rotate the polarizing film 90 degrees just like you did with the piece that was removed from the glass and the display is reversed. Excellent, this ensures that the film is going to work - until this point it was a bit of a gamble on whether or not this particular type of polarizing film would work - looks good.
Step 7: Cutting and Replacing the New Polarizing Film
Next you'll need to cut out a piece of the new polarizing film to the exact shape of the original piece. Make sure that you are cutting out the film with it turned in the right direction. Make doubly sure you have the film oriented so that it will make the display look reversed before you place the old piece on top as a cutting guide. Hint: you can tell when the two pieces are the right way because the original piece that you are using as a cutting template should look completely black. Notice in the picture below how the display is invisible without the polarizing film. Also notice the small box on the display in the upper right corner; this will be disappearing when we reverse the display using this 'hack'. The factory reversed modules manage to reverse the box too - interesting distinction.
Hold the original piece of film tightly up to the corner of the new sheet and gently cut around it using your sharp knife. Make several slices using medium pressure rather than trying to cut all the way through on the first pass. By making several slices you will avoid slipping and hopefully avoid the loss of any finger tips! Just take your time.
Once you have cut out the new piece of polarizing film, hold it over the display to make sure that it fits and that it will create the desired negative effect. The film used here (details at top) was self-adhesive on one side and had a protective cover on the other. Remove the cover from the self adhesive side and without touching it carefully place the new piece of polarizing film onto the glass screen. Use your tweezers for better precision. Gently rub the polarizing film with a soft cloth or clean Q-Tip to make sure it is adequately stuck down. Then use your tweezers again to lift of the protective cover from the front of the film. You should be left with a smudge and fingerprint free surface.
Step 8: Reassembling the Watch
The final step is to reassemble the whole thing. Carefully put the whole module back into the watch casing making sure it it seated down. I find that I nearly always have to use my tiny screwdriver to hold in the metal connectors where the buttons are in order to get a module back in. Replace the rubber spacer making sure that the protruding metal contacts show through. Then replace the metal case back and four screws. I’m not showing pictures of these steps because most of you know how to do this and if you don’t simply read through the steps above that describe how to take the module out.
When the case back is firmly screwed down, flip the whole thing over and admire your handy work, a beautiful, negative display module. Notice how the small box in the upper right corner of the display is no longer visible. This is one difference between the DIY reverse display and the factory fitted version, but I kind of like the minimal look anyway so no great loss for me.
Well that’s it. The hardest part of this whole project was biting the bullet on the polarizing film and waiting the couple of days it took for it to arrive. The rest was relatively easy.
I hope you found this a little bit useful and I also hope this encourages a few of you to pop open that old G-Shock and hack a negative display. It took me a little over four hours to do this, but nearly three of those were spent trying to replace the glass display that I shouldn’t have removed in the first place. There were also some other distractions along the way.
I’ve done my best to provide as much detail as possible, but if you have any additional questions feel free to post a comment here and I’ll do my best to answer it. Happy hacking!
65 Comments
6 months ago
The content of this tutorial seems too have been "taken", frame-by-frame by the original video of Walter Pinati on YouTube, without any credits to its own creator... fair?
https://www.youtube.com/watch?v=XNL3IOUOQbk
Reply 6 months ago
Not fair and completely inaccurate. The photos used in my Instructable were all taken by me! And I can easily prove it, not that I have to. The photos shown in the video you linked to are in fact all MY PHOTOS used without my permission. Thank you for pointing this out to me, I will proceed to take action to have the video (and use of my content without permission) taken off YouTube.
Reply 6 months ago
happy to have pointed out then; I hate copyright infringements!
Have a good day!
Reply 6 months ago
The video linked is from 2015 and this Instructable was published earlier in 2008. So that doesn't appear to be the case.
2 years ago
i did it last week exactly the other way. i converted that unreadable negative to a classy retro positive. it was a perfect square g shock 5600 2ER, with bluetooth, solar, radio controlled, 200m water resist.... but that DAMN negative display. not readable in low or dimmed light. the only alternative was a stainless steel b5000D-1er, which is crazy expensive. they want 500€ for a watch, which has the better old school display. so i decided to DIY.
negative displays are a pest.
3 years ago
wow, can this be done with a casio
Question 4 years ago on Introduction
Hi bfgreen,
I recently found your instructable (I know it's years later…). Now I ordered the foil you were refering to and found it (as on your photo with it) to be rather dark in any angle on either side. How come you have rather bright display digits after the operation?
I am planning on trying this out on the GW-9400-3ER, which has a bit yellowish and hard to read negative digits, hoping to clear them up to increase readability.
Do you think it is worth the effort on an almost new watch?
Thanks for any help you can give!
7 years ago
Hey bfgreen,
Thanks for this. I'm planning to do this soon. But I have two questions; Does this remove the "Waterproof to 200m" claim? Also, how does it look on backlight?
Anyone else who can help will be greatly appreciated.
8 years ago on Introduction
I use to have a negative display watch and the numbers were blue and when you turned the backlight on, they lit up bright blue, which made it very easy to see even in bright sun light, it was also a lot easier to see in sunlight without the backlight on, then the regular whitish gray or goldish displays. How do you convert the lcd, to show blue numbers?
9 years ago on Step 8
Where can i get polarized film?
Reply 9 years ago on Step 8
In the intro I give the name of the type of film you need or that I used and a hyperlink. http://www.polarization.com/polarshop/ (Look for a product called Linear Polarizer w/adhesive PFA). Hope that helps.
Reply 8 years ago
Thanks
Hi bfgreen, how does the light work with the negative display? Will it still display the time clearly? Thanks for the guide.
9 years ago on Introduction
awesome
12 years ago on Introduction
where did you get your new sheet of polarized material?
Reply 12 years ago on Introduction
There is a link in the third paagraph, right at the tp of this instructable. I bought mine from Polarization.com in Texas. The quality was very good, service excellent, and the shipping was pretty fast (3 days). I ordered the thinnest self-adhesive film they had in a relatively small size, the part name was: Linear Polarizer w/adhesive PFA.
Reply 11 years ago on Introduction
How was it sticking the new film on there? I'm going to get the same film as you did, thanks for the link, but I'm afraid of getting bubbles/fingerprints/dust under the film.
Do you think I would have any problems/difficulties if I got the non adhesive version?
Oh and if you do screw up - I have myself - you just repeat the whole process :)
It takes some time to clean it thoroughly. You have to get ALL of the glue reside off and that usually takes me about 10 Q-tips and a lot of Goof Off (30 mins), but is well worth doing right. Keep it very clean and dust free, the slightest speck under the film will look horrible!
IMHO you have to use the adhesive backing film, otherwise it could slide around a little. That's your call entirely, I've done this several times with sticky film and it's worked perfectly. Most recently I did a conversion of a Casio Frogman for a friend, it came out awesome!
Take your time, do it carefully and you'll be ok. - BG
I wanted to do this back when I had my 95 corvette, since those have a LCD speedometer. My 2012 Chevy Sonic has an LCD speedo as well, doing this is pretty tempting, but also scary because I dont want to destroy anything from taking it apart. Warranty wont cover that part!
