Introduction: How to Do a Cool and Simple Card Trick
I learned how to do this simple card trick from my uncle. It's really easy to do but will still amaze the person you are showing it to. However if the person asks you to show the trick to them again DON'T!!!!! The reason for this is that they may find out how the trick works.
Keep reading to find out how to do this card trick!
Step 1: Shuffle the Deck
I know that this is sounds really simple but it is the most crucial part of the trick.
While shuffling you must take a look at the bottom card and memorize it (both number and suit). This will be very important later in the trick.
Step 2: Pick a Card
Now you fan the cards and ask the person to pick a card, look at it, and put it at the bottom of the deck.
Step 3: Shuffle the Deck, Again
This is also very important you must cut the cards up to 4 times (simple but important).
Step 4: Is This Your Card?
Now take the deck and start flipping cards over. Do you remember the card that you memorized earlier? When you see this card then you flip over one more card, pick it up and ask is this your card?
34 Comments
Question 1 year ago
do you like to do magic with cards
5 years ago
It works some times just make sure you don't cut half then do it again etc
Reply 3 years ago
or make sure you do not take shuffle the card at the bottom and separate them
Reply 4 years ago
Yeeaah. You have to shuffle kind of chunky like.
4 years ago
Or when you split the deck you can check the card you check the card and ask them to sit it there. That way you 'lose' it in the deck. A lot less suspicious looking.
5 years ago
It didn't work for me ????
Reply 5 years ago
it dose not work
Reply 5 years ago
it worked for me
5 years ago
It worked
5 years ago
very god but i know it already
5 years ago
5 years ago
WWWWWWWWWWAAAAAAAAATTTTTTTT????????????? it dont work!
5 years ago
It worked but my brother's card was at the bottom so it took forever
5 years ago
nice
This was very easy and awesome
5 years ago
cool
5 years ago
This doesnt always work, when you shuffle the cards, the two cards (the bottom one and the picked card) might get separated. It works sometimes, if you shuffle just right. When you get it down, its a great, simple card trick. Thanks!
Reply 5 years ago
No, you don't shuffle after they've selected a card. you only cut. This way the cards will always stay together. Using an odd number of cuts will almost always prevent the singular trouble case of the key card on bottom and the selected card on top. The only shuffling occurs before the key card is peeked at or the spectator selects a card.
5 years ago
If they choose the bottom card, you just look for your memorized card.
5 years ago
it's good easy card tricks revealed, i wish you will share more card tricks as soon as possbile with more pictures to not have some problems while trying.
5 years ago
This is simple but amazing
