Introduction: How to Make a Chladni Plate (vibrating Membrane)
One can "see sound". Or... "A plate or membrane vibrating at resonance is divided into regions vibrating in opposite directions, bounded by lines of zero vibration called nodal lines." [wikipedia]
These are figures are made with salt on this rig.
I have seen many ways I could build my own DIY vibrating Chladni plates (Cymatics) but I was generally frustrated by the fact that one would generally have to sacrifice a speaker in the process, and I would need to have a super powerful sound amplifier. I wanted to
Sugru is ideal for this project because:
If you need to stock up on sugru, you can buy it here and also from the Instructables store.
I recommend this instructable especially for educators as it makes a great intuitive and hands-on introduction to acoustic with exciting experiments but without spending too much.
Going with this instructables, you can find classes that will teach you general concepts of standing waves, cancellation and many other phenomena.
- the physics Classroom
- UCLA acoustic
This instructable has been made by Cesar Harada at TechShop SF for Sugru
So lets get started!
- work with cheap off the shelf components
- use as much of my own kit as possible (my conventional audio amplifier etc.)
- avoid destroying the speaker
- use a plastic membrane that is cheaper and requires less power (less noise for my neighbours)
- It provides a great acoustic contact that bonds to plastic sheet, board, metal, glass
- creates a perfect seal between the speaker and the plate
- you have time to make the whole set-up level before the sugru cures
- can also create custom-made dampening pads for the contact with the table the rig sits on.
- I don't need to destroy my nice speaker since I can cut sugru and re-use my speaker once the experiment is done
- UCLA acoustic
Step 1: Build the Base
Step 2: Amplifying Cone
I bought my speaker from my local Maplin branch in the UK.
I took the speaker to my local DIY store to match it with the most suitable bucket with a matching diameter.
This one in particular is great : it is made of thin stiff metal that conducts vibrations very well. I am not sure if the membrane would vibrate more if I made a hole in the bottom of the bucket, I would imagine so.
If you hesitate, I recommend to watch the video again, it makes it much easier to understand that text.
- So the idea is to roll some sugru in long rolls.
- Install the long sugru rolls on the most outer ring of the speaker.
- Make sure that the sugru is not interfering with any moving parts.
- Flip the bucket upside down, opening facing downwards.
- Install the speaker on top of the bucket bottom.
- Adjust the level roughly with 2 mini-spirit levels if you have them
- Prepare 4 or more contact points between the speaker and the platform.
- Assemble the platform on top of the amplifying cone and speaker.
Step 3: Install the Membrane
This is quite a delicate step.
You want a lot of tension on this membrane but you do not to perforate the membrane.
I would suggest the following steps :
- Position the plastic sheet with A LOT of slack
- Hold the sheet in position with a rubber ring
- Create a "belt" of adhesive around the bucket, cut the slack
- just like when you adjust a traditional percussion, you want to adjust the tension on one side, and immediately adjust on the opposite side.
- Eventually you can gently tap on the surface and find out if the tension is correctly distributed. The idea is that it would sound like a high pitch percussion drum. In fact, you could use an adjustable drum membrane to do this even more accurately, here an awesome video of how to adjust a darbuka head skin here (watch the end, spectacular!).
Step 4: Assemble and Adjust
Before you use the rig:
- it is level
- your neighbours do not mind low and high pitch loud sound to be played.
- I recommend you use earplugs. Do not use noise cancelling headphones.
Step 5: Software
There are many softwares out there to create and play plain waves from your computer.
I personally use a mac, and I was running Tonegen demo, but I hear there are many options.
- A very simple sine wave generator by the sine wave orchestra
- MAX MSP
- Spongefork
- there is so many I let you decide which you want to use :)
- http://en.wikipedia.org/wiki/Signal_generator
You could also use an analog wave generator, again there are many out there. Would be great if in the comment you could recommend me an affordable and powerful one to make larger scale experiment. I also wonder if these experiments would work at microscopic level... Another Instructable, later !
Step 6: Play! /\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\
The frequencies I have played :
Salt, in Hertz (mouvements per second)
Maybe because of the microscopic texture and elasticity of flour... I would love to do more experiments with even presumably even stickier materials such as potato starch... Next experiments!
- 160
- 260
- 300
- 320
- 450
- 700
- 4900
- 15000
- 120
- 175
- 260
- 300
11 Comments
7 years ago
Hi..thank you for showing us this nice project..
I want to replicate it for my science fair project I've been seen a lot of cymatics videos and ended here.. So here are some questions:
- what's the material for the membrane.. monokote? cellophane?
- how do you tight the membrane to the bucket.. just duct tape?
- how much output from the amplifier to drive the 10W speaker? Will it be too noisy for the crowd attending once you begin to sweep frequencies?
- any other pattern forming material have been used: sand, powder talc, gelatin, etc?
- how did you connect the earphone output from the mac to the amplifier? a special cable adaptor? can I do the same from an iPad?
Thank You
7 years ago on Introduction
hi cesar thank you for your interesting work and i really admire because you can use laptops and don't need to destroy the speaker in the process...
i am going to do some experiments on this for my project but i need to use plates not membranes so is there any way i can put plates on this instead of membranes and still get the same pattern results? (without turning my speaker into a wave driver of course..)
My friend Giorgio Partesana made his own (better) version here :
https://vimeo.com/101561324
{in french) "Vu que j'avais peu de temps j'ai enfin utilisé un wave driver (http://www.pasco.com/prodCatalog/SF/SF-9324_mechanical-wave-driver/) et fait des plaques des differentes tailles et materiaux pour obtenir un bon rapport amplitude du son / efficacité de vibration pour ne pas trop deranger le publique.. et aussi composé une piece qu'au lieu d'utiliser de signaux continus, tres fastidieux, module des impulsion.. tu entendra sur la video"
8 years ago on Step 5
Audacity is a Good one too!
9 years ago on Introduction
Hi, I wonder if you could use this to separate materials by density? If you mix two different sizes of sand (one colored, one white)... would you get a core mass of the lighter material, surrounded by the heavier?
That is correct. From my experience from running the same frequency for a long time, I had grains of salt breaking to finer grain of salt and eventually the smallest grain would concentrate in the center when the bigger grains would progressively fall off the from the membrane. After 5 minutes at the same frequency I only had very fine salt dust left, all the big grain had fallen out.
Just hope no one applies the principle to uranium enrichment ;)
HAHAHAHAHA! Is that how you do it? mmmmm .... Interesting (with evil eyes and skinny fingers).
Oh, this is an excellent demonstration, although I doubt any professional teachers that make one will actually dismantle it, since they'll need to use it several times every year.
Good point. But what if the teacher wants to upgrade his setup? He can do that by simply cutting the sugru and attaching a new amplifying cone / membrane. Because the "glue" (sugru) is easy to remove it is an evolutive platform.
Good point, well made.
("Evolutive platform" - I am *so* going to steal that phrase!)
