Introduction: How to Use Virtual Pins in Blynk
Hello Everyone. I was tinkering with the blynk app and wanted to find a way to use the virtual pins.. Here is what I came up with so far...
Essentially this project uses and LDR attached to adc pin to switch on a virtual LED in the blynk app as a notification. I am hoping that when further widgets and more features such as MQTT, Thingspeak, IFTTT are added, this can come in handy to make easy projects such as alarms, irrigation timers, home automation etc.
Step 1: Tools
Hardware:
ESP8266 development board. I am using ESP-12 with and LDR attached to ADC pin.
Software:
Arduino IDE with required libraries(blynk, esp8266com etc)
Here is a step- by step guide how to set up https://www.instructables.com/id/ESP8266-ESP-12Stan...
Blynk app
Step 2: Virtual Pins
Virtual pins are used to interface with libraries (Servo, LCD and others), and implement custom functionality.The device may send data to the widget on a virtual pin like this:
* Blynk.virtualWrite(pin, "abc");
* Blynk.virtualWrite(pin, 123);
* Blynk.virtualWrite(pin, 12.34);
Also, virtual pins can react to value updates and requests. For example, this function will be called every time App Widget requests data for Virtual Pin 5:
* BLYNK_READ(5) { // Usually, you will need to respond with a virtual pin value. Blynk.virtualWrite(5, some_value); }
This function will be called every time App Widget writes value to Virtual Pin 1:
* BLYNK_WRITE(1) { BLYNK_LOG("Got a value: %s", param.asStr()); // You can also use: param.asInt() and param.asDouble() }
BLYNK_READ/BLYNK_WRITE functions are effectively "getters/setters" of the Virtual Pins if you're familiar with this concept in other programming languages. Please also take into account that these functions should take minimal time to execute, so avoid using sleep/delay inside of them.
N.B: taken from readme doc https://github.com/blynkkk/blynk-library/blob/mast...
Essentially i wanted to make an example to illustrate the BASIC use of the Blynk.virtualWrite() command
I made a sketch in Arduino:
the value of adc pin is read and when value <100, a HIGH is written to virtual pin 5.
the magic then happens in the blynk app where I can also visualise the adc analog value and light an LED when ldr analog value <100
Step 3: Results
As you can see in the pictures:
when LDR value is >100 the Burglar LED pin is switched off
When I shine a light on LDR, ldrvalue<100 LED is swtiched on
This is just a proof of concept.. With more tinkering I guess this can come in handy..
2 People Made This Project!
- homerruma made it!
- Optimus_Grime made it!
15 Comments
1 year ago on Step 2
Unless I missed something, it looks like your code will flood the blynk server and your connection will be shut down. Never put the write in a loop like that. You need a timer.
Question 1 year ago on Introduction
I am working on a door sensor in python and I am trying to figure out how to read the pin values into blynk. Here is my code:
import time
import blynklib
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(8, GPIO.IN, pull_up_down=GPIO.PUD_UP)
auth_token = '4JR18qzs1AWkedrhF65mjwuASpBMpeGs'
# Initialize Blynk
blynk = blynklib.Blynk(auth_token)
@blynk.handle_event('read V2')
def read_virtual_pin_handler(pin):
print(p_val)
a = blynk.virtual_write(vpin, p_val)
time.sleep(0.01)
val2 = int(GPIO.input(8))
#door is closed
return 0
elif not val1 and val2:
#door is open
return 1
while True:
blynk.run()
except KeyboardInterrupt:
print("Quit")
Question 1 year ago on Step 3
can you also set a digital pin value with a virtual pin? Mine stays low after doing that.
4 years ago
This code is wrong. It doesn't work. Please correct it like this. I wrote this program to door sensor. Thanx saurabh47 for correct code. Below code is working.
int doorSensor = 16;
void setup(){
Serial.begin(9600);
Blynk.begin(auth, "Gayan", "xxxxxxxxxx");
void loop() {
int val=digitalRead(doorSensor);
if(val==HIGH){
Blynk.virtualWrite(V2, 255); //LED 10 "HIGH"
else {
Blynk.virtualWrite(V2, 0); //LED "LOW"
Blynk.run();
Reply 4 years ago
please ! You can give yourself complete project code . thanks you
email: hoanghuuanh995@gmail.com
6 years ago
Can you post full working code?
6 years ago
It doesn't works i have usb connectivity only.please give any solution .i just want led indication. i have connected led to digital pin 6.and pin 6 also connected to analog pin a0.i have using same code just editing that
analog=anlogRead(irec)
if(anlog= HIGH)
VirtualWrite(5, HIGH);
else
virtualwrite(5, LOW);
when program is running then led is on /off by Blynk it doesn't show indication of led on blynk.
Reply 6 years ago
You are right it doesn't work ! Fix it please
Reply 6 years ago
char auth[] = "auth token";
int prev = -1;
int B1V;
int BUTTON1_P = 6;
void setup()
SwSerial.begin(9600);
Blynk.begin(auth);
// Default baud rate is 9600. You could specify it like this:
//Blynk.begin(auth, 57600);
void loop()
Blynk.run();
B1V = digitalRead(BUTTON1_P);
if (B1V != prev) {
if (B1V) {
} else {
this is pragram realy works .
here digital pin is 6.and virtual pin is v2.
Reply 6 years ago
I can't understand, did you manage to solve the problem?
Reply 6 years ago
yes i am able to solve
6 years ago
how about your setup in blynk app? did you link 5 to led indicator in app?virtual pin
Reply 6 years ago
yes, i link led to virtual pin 5
6 years ago
Thanks, hope it was helpful
6 years ago on Introduction
Nice. Thanks for sharing.
