Introduction: Ice Age - Meltdown! AKA LED Stalactite
Greeting to the community!
My first instructable and hopefully there will be more. :)
This is easy way to make great home decoration for living room, kids room or your bedroom. Photos are not clear enough but you are gonna get the point. Pardon my English because I come from Serbia where English isn't spoken.
Step 1: Parts and Tools Required
For this ible you will need:
1. hot glue gun
2. several hot glue sticks
3. piece of aluminium profile 15x15x1.5mm, about 55cm long
4. RGB LED strip, 50cm long
5. hot air gun
6. optional RGB LED strip controler ( I didn't use it but you could )
Step 2: Mounting Strips and Cutting Sticks
First You mount LED strip into the profile and then cut some hot glue sticks to various lenghts. Mine are around 5-10 cm long.
Step 3: Hot Glueing, Hot Glueing and Some More Hot Glueing
Hot glue Your sticks onto every second LED. Just apply hot glue to one end and press it on LED. Add some more glue on the sides. Continue with other sticks till you get bored...:)
Step 4: Meltdown Time!
Use hot air gun to melt down sticks one by one. When they start to melt, dip the stick in glass of cold water until it solidifies. Set temperature around 330 degrees centigrade and fan to the minimum so you don't hurt yourselves like myself. Fan was too strong and I had burns on my arm. :(
Step 5: Final Product
And this is the look of final product. You can mount it under your TV set or kitchen cabinets...You will think of something I'm sure. :)
I didn't use LED strip controler but you can, and make mood light with it.
Step 6: Friendly Advice
I made a mistake first mounting sticks and melting them afterwards. It is better to melt your sticks first and later glue them into the aluminium profile. It is far more easier and time effective.
Bedroom Contest
Crafting 101
Halloween Decor Contest 2015
Reuse Contest
