Ice Claws
Intro: Ice Claws
20 days ago I was in the field. And there was snow and ice...and I slip down. So, I decided to buy ice cleats/crampons. Well, here was limit on real alps high quality stuffs ... i.e. high prices. So, went to nearby metalworking shop...
STEP 1: Start
See.
T profile plate 2 mm thick. with holes for screws. Zinc protected against rust. A 25 mm steel screws, zinc protected, for metal. Self drive in.
STEP 2: Tool
I took a saw, a rasp and a rasp and a wrench....shorten T profile, extend holes for future strip, and start to screw bolts. Some holes should to be adjusted, to match the screw.
STEP 3: Looking How Should Be Fastened
As you can see, some heads of bolts suddenly find a place between ribs...
STEP 4: Reinforcements
In spite the bolts hold tight in T plate, to avoid unscrewing, I decide to use small torch and put simple zinc wire to fasten heads.... after I cleaned - wash this with gasoline.
STEP 5: Testing
Well, later I add strip and clips, and tray it out in the field on frozen waterfall...
I menage to stand still and secure, to move, to climb, to take a photos ... from the point which is without this..... impossible.
STEP 6: This Is That
That is this.
Well, now I have help, for eventual situation. Not heavily to carry in backpack, cheap and strong.
Its work for me,
Yours on your responsibility.
Sincerely yours.
Its work for me,
Sincerely yours.
56 Comments
footmatters 5 years ago
GurubandhuK 8 years ago
Does anyone know where to get the T profile plate? I went to both Lowes and Home Depot, looked in the trussing area and did not see one like this. Any suggestions?
Kobudoka 10 years ago
Nice. Simple. Usable :-D
Henge 11 years ago
DWordDtour 13 years ago
KresimirPregernik 12 years ago
Ferguson199 13 years ago
I'll be using 1/4" screws the 1" you've got there seem a bit long.
Good job on making these!
wario235 13 years ago
Wasagi 13 years ago
abadfart 13 years ago
ThinkBeforeYouSpeak 13 years ago
KresimirPregernik 13 years ago
Krešimir Pregernik
alaskanbychoice 13 years ago
criggie 13 years ago
I use petrol and turpentine for cleaning bike parts, or sometimes engine cleaner aerosol spray. For non oily things, a spray bottle with water and dishwash and a dish brush then a rince with the hose.
Your turn.
hstueckler 13 years ago
tmack0 13 years ago
That depends on your location in the world. I know the US cut their fuel with ethanol to alter the RON, doubtless other places do. But not here in New Zealand.
I've never had a problem with paint being stripped by cleaning, unless its already loose and flaking or rusting.
And petrol (gasoline) is still cheaper per litre than all cleaners other than soapy water.
Decent gloves help protect the hands of course.
It is dangerous. We know all about other solutions....
Don't worry. :))
sisar 13 years ago
thanks mate
