Ikea Kitchen Toekick Drawer
Introduction: Ikea Kitchen Toekick Drawer
While installing my Ikea kitchen, I figured out a way to add a toekick drawer without any special equipment. This was pretty easy because I did it before installing the cabinets, but it's theoretically possible to retrofit an existing cabinet. I found that a drawer designed for a 30-inch cabinet fits perfectly under a 36-inch cabinets with toekick boards installed onto the feet underneath. I haven't tried it, but I suspect that a 24-inch drawer would fit under a 30-inch cabinet and a 18-inch drawer would fit under a 24-in cabinet.
Step 1: The View Underneath
I wish I'd taken pictures of this during installation, but hopefully this will be clear. I used a 36-inch cabinet with 4 legs on the outside. Then I installed the toekick boards on the side legs to support the drawer rails. I used a scrap piece of 2x2 on the inside corner to keep it solidly in place. You'll have to drill pilot holes in the board in order to install the drawer rails, and check really carefully to make sure you're getting the locations right.
Step 2: The View From Outside
Another view of the rails and support
Step 3: The Finished Product
Voila! Extra storage space for very little. It's not a huge drawer, but it's good for holding big things like cake pans. The front is more toekick board with the iron-on veneer on top. The front attaches with the same hardware that comes with the drawer for regular drawer fronts, but you'll have to drill pilot holes to install it. It's really tricky getting the measurements right, so triple check everything before drilling.
Be the First to Share
    • Fabric Challenge
      Fabric Challenge
    • Remote Control Contest
    • Sculpt & Carve Challenge
    10 Comments
    shooby
    shooby
    13 years ago on Introduction
    Toe-kick, so you kick it to open it? Nice. Still have to bend down to get the item though, unless there's a toe kick ejector button as well.
    skipperkimmy
    skipperkimmy
    Reply 2 years ago
    Ikea sells the device for $8 push to open the toe kick. I will be doing a complete kitchen remodel in June and adding some to my kitchen.
    JakeTobak
    JakeTobak
    Reply 13 years ago on Introduction
    A Toe Kick is that recess at the bottom of your cabinets, you don't actually kick it to open the drawer, although I'm sure you could make one like that if you wanted.
    noahh
    noahh
    they make drawers that open when you push them, so (in theory) you could make one close to the ground so when you push on it with your toes it would open!
    shooby
    shooby
    Ah, I see, thanks man. Pretty cool idea in that case, in terms of extra storage.
    torontoqt
    torontoqt
    5 years ago
    How high off the ground is the bottom of the base cabinet? (how many inches of clearance is required?)
    DebC1
    DebC1
    7 years ago on Introduction
    Well, I think it is pretty clever way to used previously unused --yet valuable--kitchen space!! My husband devised a vertical spice rack for me, using a 5" area between wall cabinets. When our son, the carpentar, got done with it, it was amazing! The lesson here is this: Use what you have to the fullest!
    thequara
    thequara
    11 years ago on Introduction
    I like the collection of peanuts and other debris under the drawer! Haha! =)
    davialyn
    davialyn
    12 years ago on Introduction
    I tried to do this, but was not successful. The drawer stuck out as far as the base cabinets instead of being flush with the toe kick.
    terrilynnt
    terrilynnt
    I have never ever seen this idea before and I think it is amazing! My kitchen is rather small and am always fighting to find a spot for this exact items! This would be perfect! If I ever get to build my own kitchen, these are going to be a must!
