Introduction: Installing WAMP Server
How to install WAMP server so you can use Apache, PHP and MYSQL. This is a prequest to Beat the School Website Blocking System.
Step 1: Download WAMP
Download WAMP server here. Select save or run. Click open. After that follow the next steps.
Step 2: Configuration
Just press next.
Step 3: Configuration
Selcet "I accept" and Press next.
Step 4: Configuration
Select where you want to save it. If you can't decide just leave it as it is. Then press next.
Step 5: Configuration
Type the name you want to appear on the Start Menu. Then Press next
Step 6: Configuration
If you accept this, your computer will be quite slow on startup but do what ya want. Then click next
Step 7: Configuration
Just let this one run.
Step 8: Configuration
Type your email (I suggest you make a new email account from hotmail or something). Leave the next window as localhost unless you know what you're doing.
Step 9: Final Config
Just press Open and then finish and ur done!!!!
1 Person Made This Project!
- greg_almond made it!
12 Comments
6 years ago
Hi, I have made a written version of Intalling WampServer on Microsoft WIndows here, http://technospace.xyz/install-wamp-server-windows-7810/ I am sure it will help out users to install this , the steps on mine are pretty simple and easy.
6 years ago
Thanks for sharing this. It will help many. I too came across such where they explain in detail. I want to share that here http://www.allinformer.com/how-to-install-wampserver-on-windows/
7 years ago on Introduction
Ok so I downloaded, followed typical install (as above). Once installed I got error message: can't run because missing MSVCR110.dll. Said to run the install again, so I did. Same thing. I uninstalled all componenets, downloaded again. Reinstalled and got same message. What am I doing wrong?
Download file MSVCR110.dll and copy to the system32 folder
that's all.....
Thank.
I tried wamp, xampp and even mamp and finally play with Laragon (http://laragon.org/). It supports Memcached, Redis that are my tech stack.
Funny I love Aragorn also.
8 years ago on Introduction
Clear, Simple and Helped.
Thanks Dude...
Hi, i found some detail steps regarding installation of WAMP server on this link..
http://code.freefeast.info/php-tutorials/setting-up-the-environment-for-php-php-tutorial/
11 years ago on Introduction
I just started using wamp on mswindows, but I have not had that issue. I will check it out.
My wampserver install: https://www.instructables.com/id/Home-Automation-MSWindows-XP/
If you use ddns, you can get a domain free for a limited time.
Once you start using a web server, you will wonder why you never used one before. I run my private apache web server on an old an old pII. It is currently running Ubuntu though I prefer debian when I am not running centos. I had it on I think ubuntu server 6.x and have done in-place upgrades as they came along the way to 9.x. (i.e. no reformatting or disk wiping). This is an example of the actual web pages i run on it. https://www.instructables.com/id/Uses-for-your-own-private-cloud/ I have since added doing home automation on it. Keep finding uses for that legacy computer. Microsoft Windows Supporters said I should have thrown away a long time ago. It is not what you use, but how you use it.
13 years ago on Introduction
After i did all this installation, what i found out was apache server was not running. When i took mouse pointer to tray icon of wamp, it said "one of two services running". Plz can anybody help?
Reply 12 years ago on Introduction
Me too.
Reply 13 years ago on Introduction
I would help you, but I did this instructable so long ago, and plus, I'm now on Mac so I'm afraid I can't help you. Try looking on the internet and asking in the questions section of Instructables.
after step 9 the installion gets hangs up and it is not working but the wampserver is installed in my pc but when i run it the icon came at tray bar but not working wat should i do any can help me with this plz send me the answer also in my sbwakilzada@hotmail.com
