Introduction: Instructables - HOW TO MAKE a LIGHT TABLE
Recycle, that is the theme of these instructable
I have a lamp with a magnifier and a fantastic “FUJI Digital Camera” that I have had in storage that I have not used in more than a year.
Step 1:
I need a light table to create pictures of pages out of an old textbook that I would like to publish in Facebook
This is a great project I can do at the TechShop
Step 2:
I first need to remove and clean up the magnifier from the lamp
Step 3:
I have found a small piece of scrap metal in the TechShop Sheet Metal Shop
Step 4:
I cut the metal and adjust it to the size I need
Step 5:
Then I punch holes in the metal
Step 6:
Like this
Step 7:
Then I round and smooth out the corners
Step 8:
and bend in the vise
Step 9:
into the shape I need
Step 10:
I screw the support into the Lamp
By the way, I made the window sticker at TechShop too.
(the sticker in the background, I made it at Techshop too :)
Step 11:
I then screw the camera in the support
Since I did not use this camera for more than a year, I was disappointed to discover that the camera did not work!
It is always a good idea to test the parts before starting the project ….ahaha..
Never give up!
Let’s go buy a new FUJI Digital Camera
Never give up!
Step 12:
I have bought my new camera
Now I find the position of the screw to mount the camera in the support has changed :(
Step 13:
It turns out the door for the battery and SD Card in the new camera is positioned differently, now I can put the support screw in a better position
so now my original project will not work :(
but I never give up ….ahahha...
I will create an interface piece between the support and the camera
Step 14:
I am going to describe the process to create this interface piece since it is the same process I used to create the original support. The final result is that you can create an interface with multiple possibilities.
Step 15:
(new camera, old support and new interface part)
Step 16:
And that is the first picture in the new set up :)
some manipulation is needed
like a neutral back ground, perfect alignment of the frame, focus....ahaha...
but anyway, we are in the way
see you in my next project instruction :)
Yep, I made it at Techshop
