Introduction: Key Ring, Letters!
Project Overview:
In this project you will learn to make a key ring using letters!
Check out the entire project on Tinkercad
Step 1: Place Your Letters
Time to get creative. Design one for your friends or yourself.
Instructions
- Start by dragging the letters to the red base (found under Design Starters > Letters and Numbers).
- Note that you can find the red base in the same category in the Shapes Panel if you don't see it.
- To make positioning the letters a little easier, change the snap grid setting from 1.0 to 0.25.
- After placing a letter, the arrow keys on the keyboard will let you nudge the letters in any direction.
- Continue to the next step.
Step 2: Resize the Red Base
Great! Now adjust the size of the red base to fit your name.
Instructions
- It's easy to resize the base using the black dot on the right of the model
- Click on the shape to select it, then drag the black dot until the red base matches the size of the letters.
Step 3: Clean Up
Now do a little clean up work by removing any left over letters at the top.
Instructions
- You can click and drag your mouse across all the letters to select them.
- Then, press the delete key on your keyboard to remove the selected letters.
Step 4: Group the Remaining Shapes
Now group the left over shapes into a single object.
Instructions
- Select all remaining shapes.
- Group them together by clicking on the "Group" button on the toolbar.
Step 5: Congratulations!
Great Job! You made it!
You can now create custom designs of your own!
You Rock!
