Introduction: Khem Vertical Garden
A vertical garden with a checkered layout.
Wood, soil, screws, L-shaped metal brackets, drill, saw, plants.
Step 1: Cutting the Wood
With your provided shop bot, cut 16 6in x 2ft pieces for the front and 16 6in x 6in for the sides. You would also need 6in x 4ft for the poles that the boxes will go on and you will cut 8 6in x 2ft bottom pieces.
Step 2: Building and Setting Up the Boxes
Connect 2 6in x 2ft pieces with 2 6in x 6in pieces with a 6in x 2ft piece on the bottom and drill them together with nails of your choice. You will be making a box with these pieces. Then, drill the 4 6in x 4ft poles on a wall around 18in away from each other and drill the boxes onto the poles with a checkered pattern.
Step 3: Putting Soil and Plants in the Garden
Put desired amount of soil in the boxes and plant desired plants. Enjoy gardening! :)
Step 4: Additional Resources
Link to Budget List: https://docs.google.com/spreadsheets/d/1xEaIH-ceJmtiTjplXEJD9y47J1H1buQgXjFgfuPJLvA/edit#gid=0
(Materials Are Also Listed There)
