Introduction: Kuzhi Paniyaram (Dumplings)
Kuzhi paniyaram are dumplings made from rice , urad dal & fenugreek seeds . Its an authentic Chettinad dish .A special pan is used to make paniyaram and its called as paniyaram chatti . In Indian market one gets both non-stick as well metal pans..
Paniyarams are also a south indian tiffin or breakfast snack and they are healthy like most south indian food.
You can make 2 versions of paniyaram with the same batter.. Isn't it cool :) :)
Ingredients :
1) Raw Rice - 1 Cup
2) Idly Rice - 3/4 Cup
3) Urad Dal - 1/4 Cup
4) Fenugreek Seed -1/2 Tsp
5) Water needed to grind.
Step 1: Grinding Batter
1) Wash the rice , dal and fenugreek seeds and soak it for minimum 4 - 5 hours (soak fenugreek seeds along with the dal)
2) Then grind them together in a blender (I used wet grinder) by adding water little by little till they are ground into a smooth consistency.
3) Transfer it to a clean container and grind the soaked rice to smooth consistency.
4) Place it in a warm place and allow it to ferment.(8 - 12 hours)
kuzhi paniyaram batter is ready!!!
Step 2: Sweet Version
Ingredients for Sweet Kuzhi paniyaram
- Raw Sugar as per your taste
- little water
Method
- Heat a pan in a low flame.Add the required amount of Raw sugar add a little bit of water
- Let the raw sugar melt, once melted Pour it into portion of batter taken
Making Sweet Paniyaram
Heat the paniyaram Chatti/Tawa.
Add a few drops of oil.
Pour spoonful of the batter 3/4 of the paniyaram mould.
Allow the batter to cook for 3-4 minutes on a low medium flame .
Turn each kuzhi paniyaram with the help of a wooden skewer or spoon and drizzle a little more oil .
Now allow the other side to get cooked and crisp. turn once or twice for uniform cooking.
Remove paniyaram and keep in a vessel/container so that they stay warm.
Step 3: Salt Version
Ingredients for tempering Kuzhi Paniyaram (Salt Version ) Recipe
- Oil 2 teaspoons
- Mustard seeds 1/4 teaspoon
- Urad dal 1/4 teaspoon
- Curry leaves chopped 10-12
- Onion finely chopped 1 large
- Green chillies finely chopped 2-3
- Salt to taste
Method :
- Heat two teaspoons oil in a pan, add mustard seeds, urad dal, curry leaves, onion and green chillies. Saute for two to three minutes. Add tempering to the portion of batter taken . Mix well.
- Heat the paniyaram tawa over medium heat and put 2 drops of oil each dent with a little oil. Pour 3/4th batter in each dent, and cook for four to five minutes till the underside is done.
- Turn them over with the help of a wooden skewer or spoon and drizzle a little more oil and continue to cook for three to four minutes or until both the sides are evenly cooked. Prepare more paniyarams similar way..
Serve hot with chutney/Idli Podi
Note :
If the batters is fermented its a quick task to make it as breakfast/snack..
These kuzhi paniyaram are also good as tiffin box snack or picnic snack.
You can either use Raw sugar/Jaggery
