Introduction: Ladder Ball From Reclaimed Wood
I wanted to build a ladder ball set with some materials I had lying around the house so I decided to make an Instructable on it. It was a very fun, and easy build and I hope you enjoy it.
Step 1: Find Materials
I built the entire set from scrap lumber and materials. The 2X4's are from an old tree house I took down and the dowels are from old broom handles. I found only two golf balls but in reality you are going to need 12. Here is the total list:
• 14 feet of used 2X4
• 8 feet of 2X2 (I used a 2X4 and cut it in half on the table saw)
• 6 lengths of 3/4 in. wooden dowel each being 20 inches long
• drywall screws
• some rope (the length of your forearm)
• 12 golf balls, but I only found enough to make one bola
Step 2: Cutting Down to Size
I used my chop saw to cut everything down to the correct size. Make sure to measure and cut carefully to keep everything square.
Step 3: Drilling
You will need to drill three pilot holes in each 2X4. The first is 3 inches from the top and centered in the middle of the board. The second is 20 inches down from that and also in the center. Finally, the third is another 20 inches from that, also centered. After the pilot holes, I used a countersinking bit but this is optional. Finally, I made a small pilot hole in the center of the dowel as well.
Step 4: Screws
This step is relatively simple and it helps if you have a friend. I had my dad hold the dowels while I screwed them in. I there is a slight misalignment, you can often just bend it back into shape.
Step 5: Base
For the base I just took 2 foot pieces of 2X2 and used 2 screws to secure them to the base. I was originally going to brace it a little but I realized that it was strong already and the forces involved with the game were very small.
Step 6: Bolas
For the bola, I simply drilled a 3/8 in. hole halfway through the ball, filled it with gorilla glue, and pushed in a small section of rope.
Step 7: Finished
After the glue dries, take it outside and play! It is actually a pretty fun game and we play it at gatherings and parties. The best part is, I didn't spend a single penny on the project.
Please vote and favorite!
Glue Contest
Great Outdoors Contest
Pallet Contest
6 Comments
4 years ago
Not sure if my math is correct, but we have 14ft of 2x4 for the 4 uprights. Meaning 3.5ft (or 38" per upright).
If the top hole is 3" down, next hole is another 20" down and third hole is another 20" down, that's a total of 43". Which would be able to work with a 38" upright?
Reply 3 years ago
As well, the photo where the uprights are being cut says 42" which makes things more confusing.
I'm going with 3" from the top and 14" between.
8 years ago on Introduction
Nice job. I made one out of PVC, but the golfballs broke it too easily. Plan to make yours this summer.
8 years ago
Thanks! It is a really fun game I think, and it was even more fun to build.
Wow, I've always wondered about this game...I can see one in my neighbors yard when I jump on the tramp! Haha! Great job--sounds so fun! :)
8 years ago
looks interesting. How is ladderball played?
