Week 3: Lamp Shade With Rhino
Introduction: Week 3: Lamp Shade With Rhino
I want to design something spherical and has some carved patterns on it. So light can come through easily with some shading effects.
My thought is to design a spherical surface, design some patterns, and do surface morph.
Step 1: Design and Test the Lamp Holder for Fitting
I checked my lamp and it has a lock that rotates and locks the lamp shade fitting connections. So I designed something similar that could fit the fitting (white object printed).
Step 2: Pattern Design - Circle Packing
To realize the idea of patterning on a surface, I found a useful tool called 'imgcircles' in Kangroo. Here is a link to some related examples: https://www.grasshopper3d.com/photo/circle-packing...
The imgcircles tool packs images with different sized circles according to the image's color gradient mesh. I used a simple black and white image as input, and generated a packed circle of smaller circles. To make it to be used as patterns, I did some other operations we learned in the class to make the pattern a polysurface.
Step 3: Spherical Polysurface Mesh and Morph Surface
I have a problem with the parametric method:
The parametric method generates the polysurface mesh. But it takes very long time for me to wrap the pattern on the surface. There are also a lot of faces that I need to select. I tried converting mesh to surface, but it still takes forever. I think maybe because the generated parametric surface is too complicated for morphsurface.
So I moved on with a simple sphere component and it worked!
Step 4: Boolean Objects Together
I boolean the holder and the lampshade together first, then use the 'split' tool to split the extra parts using the overlapping surfaces.
In the first model I generated, many circles are tangent to each other and that causes some disconnection problems. So I modified the circles shape to make spacings between them and finally the model is showing good in Cura. Can't wait to see how our printer handles this geometry.
Step 5: 3D Printing
After some failures, finally the printer worked fine and started to print normally. The resulting print has some issues at the bottom and at the top layers. There are also issues in the overhang area on sides. I expected that because I did not want to use support materials. But overall, it looks great! I trimmed the overhanging materials on one side and left the other side as it looks pretty good.
Be the First to Share
    • Remote Control Contest
    • Fabric Challenge
      Fabric Challenge
    • First Time Author Contest
    5 Comments
    stejaraiulia
    stejaraiulia
    2 years ago
    Mengjia this is so beautiful!!! Well done!
    sambourgault
    sambourgault
    2 years ago
    WOW Mengjia! Your lampshade looks great! May I ask how long did it take to print?
    mengjiazhu
    mengjiazhu
    Reply 2 years ago
    Thanks Sam! It took about 1 day 11 hours to print!
    soniahashim
    soniahashim
    2 years ago
    Wow I can't wait to see what the printed result on a lamp looks like with the pattern you came up with! Thanks for sharing the circle packing tool. Also -- it looks like the sphere has cutouts -- did you do this in GH / Rhino or is this a part of the circle packing surface morph?
    mengjiazhu
    mengjiazhu
    Reply 2 years ago
    Thanks for your comment! I will update the post with printed lamp shade when it finishes. The cutouts are from surface morphing step. The circle parcking tool only gives curves, so I extruded it to make it a polysurface.
