Introduction: Legend of Zelda, Triforce Pillow
In this instructable, I will show you how to make a Legend of Zelda, Triforce throw pillow using Tunisian crochet.
Step 1: Step One, Gather Supplies
Supplies:
- Yarn bobbins
- Scissors
- Afghan, or Tunisian crochet hook
Materials:
- Dark green yarn (worsted weight, but I used Redheart acrylic)
- Bright yellow yarn (worsted weight, but I used Redheart acrylic)
- Poly fill, or Fiber fill. Something to stuff your pillow with
Step 2: Learn to Make a Simple Tunisian Pattern
We are going to make a simple 10x10 swatch using a cross design. The image of the cross is going to be our pattern. You may want to print it out, so you can mark off each line as it is completed.
Here is a youtube video I created on how to follow the pattern.
The pattern has 10 boxes, horizontally, so let's begin by chaining 10 stitches.Insert your hook into the closest stitch to our hook, yarn over and pull through.Repeat in the next stitch. Do this in every stitch until you have 10 loops on your hook.
Each row of the pattern requires two crochet passes. The forward pass and the return pass. We just completed the forward pass, now let's do the return pass.
For the first stitch coming back, yarn over and pull through ONE loop only.For the remainder of this pass, yarn over and pull through two stitches. Repeat until the end of the row. That completes row one, now repeat for the remainder of the rows in the pattern.
When you come to a different color box in the chart, you have to change yarn colors. Just simply loop the new yarn over the hook and pull through.
Once you are finished with your last row, it is time to bind off. Insert your hook through the first stitch in the forward pass, yarn over and pull through as you have been the entire time. You will now have two loops on your hook. slip the left most stitch through the right most stitch. This is called a slip stitch. Do this for the remainder of the stitches in the row, cut your yarn and you are done!
I know this can sound daunting by just reading instructions. Please watch the youtube video for a better understanding.
Step 3: Now for the Real Deal!
Now it's time to apply the skill we learned in step two. Even though this pattern is much larger, the concept is exactly the same. Don't get intimidated.
- Chain 61 stitches because there are 61 columns in our pattern
Insert your hook into the closest stitch to your hook, yarn over and pull through.
Repeat in the next stitch. Do this in every stitch until you have 61 loops on your hook.
- For the first stitch coming back, yarn over and pull through ONE loop only.
- For the remainder of the pass, yarn over and pull through two stitches. Repeat until the end of the row.
Step 4: Backside of the Pillow
For the backside of the pillow, I just made it the same size, (61 columns by 41 rows), using solid green.
You may want to get creative here and put another pattern on the other side, maybe the same thing, maybe something different.
When you are done, you should have the two panels of the pillow, the front and the back.
Time to sew them together....
Step 5: Sew the Panels Together
- place the two pieces back sides together
- Using a large needle and matching color yarn as thread, sew the squares together.
- Insert the needle through the first loop on each panel and pull through.
- Repeat this for each stitch around all for sides
- When you have about 2 inches left to sew, stop there and add the fiber fill.
- Stuff as firm or as soft as you want, then finish off your sewing.
Step 6: Border Around the Edges
To give your pillow a nice finished look, use a regular crochet hook and just do a single crochet in gold yarn all the way around. You may want to do two rounds, it's your preference.
If you have any questions about this, I will be more than happy to answer any that I can. Good luck!
Runner Up in the
Fiber Arts Contest
19 Comments
Question 2 years ago on Step 6
Hello! Really new to Tunisian crochet and saw this pattern. I am looking at the backside of the pattern and see all the yarn waist. Do you cut small sections of the design as needed? Or do you just let it go behind the pillow? I don't mind so much on the areas where there is a lot of yellow or a lot of green keep that same color, but when the color is sparse there are feet upon feet of waste. Please advise the proper way.
2 years ago on Step 5
Steaming your Tunisian projects relaxes the yarn making it flat. Looks great!
4 years ago
gonna make this totally rocks
6 years ago
That is a royal crest, or Wingcrest, not a Triforce.
great instructable btw
7 years ago
What size tunisian crochet hook?
8 years ago on Introduction
I am knitting this pattern rather than crocheting and I was wondering if you had the finished dimensions of the pillow. I am trying to decide between using fiberfill or using a pillow form. Thank you!
Good Day, Love the pattern and am interested in making it. I do not want to buy the program but am willing to purchase the pattern. Is there a way of doing this. thank you for time. The video was very informative now I am interested in adding colours to a project, thank you
9 years ago
Dis wiil make her happy
9 years ago
I'm making one of dis to my friend lol
9 years ago on Introduction
Wow, I love this. I'm really going to make this for my boyfriends birthday. But what is the size of the crochet hook you used? And what are the measurements of the finished pillow?
this is the first time i used this method ,and i love it!! I think its easier than regular crochet, i also like the fact the pattern is different and much easier to read, i was wondering how you made it? did you color each tile on excel till it was right? Im starting college this year and would love to make a pillow with my school logo but i cant figure out how to make the patter on excel.
10 years ago on Introduction
Congratulations on being a finalist in the fiber arts contest!! Good luck to you!
Fun stuff! I'm going to have to start working on this one!
You know, I've never seen this method before. Do you prefer it to traditional crocheting?
I prefer the finished product, especially for things like scarves because it is much thicker and warmer. And I also like the fact that doing color work comes out so much clearer since each stitch is almost a perfect square. The only downside is that the work curls really bad unless you border it, and it takes twice as long because each row requires two passes as opposed to just one.
That is a really cool method :) I wondered why that one crochet hook in my crochet starter kit had that flat end!
I really like this technique. It seems like a really good way to form pixel art.
I realise that the gauge doesn't really matter on this project, but I was wondering what size hook you used and how large it has made the final product?
This rocks plain and simple!
