Introduction: Linux Serial Port Communication With Arduino Using Python and Pyserial
Learn how to setup a serial port communication link between a Linux PC/Laptop and a AVR/PIC/MSP430 Microcontroller or Arduino using PySerial and Python.
Here we will Learn the following
- Setting up permissions to read and write to a Linux serial port,
- How to solve the /dev/ttyUSB0 or /dev/ttyACM0 access denied error.
- How to add a user to tty and dialout groups for serial communication on Linux
- How to solve dmesg :read kernel buffer failed :Operation not permitted error
- Python Interpretor
- Arduino
- Ubuntu/Linux system
Step 1: How to Install Pyserial on Ubuntu Linux for Serial Port Programming
How To Install PIP Package Manager On Linux
Check whether PIP is installed on the System,
if not, install with the following command, You can also check the link above to the video.
sudo apt install python3-pip
After installing PIP ,use it to install the latest version of Pyserial
How to install PySerial on Linux (Ubuntu 22-04-LTS) using PIP Package Manager
use the below command or check the above video link ,if you get into trouble while installing Pyserial
python3 -m pip install pyserial
Step 2: How to Identify the Serial Port Name / Number of Your Device in Linux (ubuntu)
In Linux there is no concept of COM number, instead the
- hardware serial ports are numbered as ttyS0,ttyS1 etc ,
- USB to Serial Converters as ttyUSB0,ttyUSB1 etc.
- Arduino's as ttyACM0
Connect your Arduino to the USB port and issue a
sudo dmesg | tail
command at the terminal.
You have to use sudo in front of dmesg otherwise you will get a dmesg :read kernel buffer failed :Operation not permitted error.
So in Linux change the second line to
SerialObj = serial.Serial('/dev/ttyACM0')
for Arduino
More details on serial port programming on Linux can be found here
Step 3: Making Python Serial Port Code Executable
Before running the python code ,you have to make them executable by using the chmod command
chmod +x yourpythonfile.py
Step 4: Adding the User to Tty and Dialout Groups for Serial Port Access in Linux (Ubuntu)
On Linux to access the serial port the user must be part of 2 groups
- tty
- dialout
You should add yourself to these two groups using the usermod command.
Please note that you should have permission to run the sudo command (part of the Sudo group in Ubuntu) or part of the wheel group in Centos/RHEL/Rocky Linux.
Adding a user to tty and dialout groups for serial port access.
sudo usermod -a -G tty [username]
sudo usermod -a -G dialout [username]
replace [username] with your username Eg rahul or molly.
The -a makes sure that you are appending the user to the groups .if -a is missing you will get unsubscribed from all other groups except tty and dialout.
After the commands are run,
Logoff from your account and then log back in so that changes are saved.
Step 5: Running Python Serial Port Communication Code on Linux
After this you can run the code files on the linux system
