Introduction: Make a Custom Lift-the-Flap Book for a Toddler
I provide childcare in my home for three toddlers and I've noticed that they really love board books with flaps that open. So for Christmas I made three customized lift-the-flap books for them. This instructable will explain how to make your own and give some tips on how to make the process a little easier.
Step 1: Edit Photos
Before assembling the book you need to create two prints for each page. During step 2 you will cut through the top layer to make a flap which will reveal someone (or something) on the layer underneath. This is easiest to do with a photo editing program that supports multiple layers. (Photoshop Elements 2.0 worked fine for me.)
Note that I only printed the first two images. The second two are just to help explain how to use multiple layers for alignment. I found it helpful to cut the windows out of the top layer and place them on a separate layer in Photoshop. That way I could hide the layer with the windows temporarily while I dropped my images of mom, dad, Elie, and the squirrel onto a layer under the top layer for scaling. Since the windows are cut out and hidden you will be able to see the people through the openings and scale them to fit. Then you can turn the layer with the windows and doors on and off to test the flaps.
Once you have made the two layers for each page and a front and back cover you can print out all your prints either at home if you have a photo printer or at your local print shop. (I printed mine over the internet to the one hour photo center at Walmart.) I would recommend a matte finish which won't show fingerprints as quickly as glossy.
Step 2: Cut an Old Board Book to Size
On your way to pick up your photos at the print shop swing by your local thrift store and get a board book to use as a base. The book should be at least 4x6 inches in order to fit the prints. I cut mine down to exactly 4x6 inches to match the prints using a saber saw with a fine blade. You could also use a utility knife to cut one page at a time. I spray painted the binding black to hide the old book title.
As another alternative (which I'll probably try on my next book) you could glue the photos onto individual pieces of cardboard and then bind it yourself or take it to a print shop and get it spiral bound. Using an old board book as my base spared me from dealing with binding the thick pages but it ended up making it difficult to close the book due to the extra thickness of the four prints between pages. This isn't all bad though because it makes it much easier for a toddler to turn the pages since they stand apart.
Step 3: Cut the Flaps
This is the trickiest part of the project. Take an Xacto knife or razor blade and carefully cut three sides of your doors and windows to make flaps. Make sure you have a good sharp blade in the knife and use a metal straight edge to make nice straight lines. Wouldn't a laser cutter would be handy for this task?
TIP: It's a good idea to plan your book before you start cutting so you know which images will be for left hand pages and which will be for right hand pages. Then when you are cutting the flaps always put the uncut edge toward the inside of the book. That way the flaps will automatically close when the book is closed. If you put the uncut edge toward the outside of the book (or top or bottom) you will tend to have problems with the flaps getting squashed or pressed into the open position.
Step 4: Glue the Prints Onto the Board Book
Once you have all your flaps cut you can start gluing the prints onto the board book pages. The bottom layer prints can just be sprayed and then attached to the board book but the top layer prints will need to be protected with low tack masking tape or other shielding to avoid getting spray glue on the flaps. (You obviously don't want to glue your flaps closed!) I supported my prints on wire mesh. If you just laid them directly on newspaper and then sprayed on the adhesive you would tend to have problems with the edges of the prints sticking to the newspaper.
TIP: I used 3M Super 77 multipurpose spray adhesive. It worked great for this project but I have a very important tip. Don't spray a print and then immediately try to glue it into the book. You will get glue on your fingers and then onto the print and it will be much messier and more difficult than necessary. Instead, layout all your prints and spray them all at once, then wait 5 minutes for the glue to partially dry. After 5 minutes the prints will still stick very well to paper but will hardly stick to your fingers at all.
Step 5: To Finish
Most important final step: Leave the book fanned open with all the flaps open overnight to dry completely. The last thing you want at this stage is to glue your flaps shut or to glue entire pages together.
One other minor detail I added was a title on the binding. I just printed out some text on my laser printer, cut it down to a narrow strip and then used clear packing tape to attach it to the binding. I also used the spray adhesive to attach single prints (no flaps) to the front and back covers.
By the way, if the whole process of making two layers and cutting the flaps sounds too complicated, you can still make a fun custom book for a toddler by making single prints in Photoshop (like image 3 on step 1) and just gluing those onto a board book.
25 Comments
6 years ago
Looks hard... but going to attempt!
9 years ago on Introduction
sweet!!!
13 years ago on Introduction
Awesome Idea. I'd love to make one of San Francisco for my kids who love board books....
Reply 11 years ago on Introduction
dude i was thinking the same things i liv in the mission , cool to have my lil ones bear hiding on the bridge ...
wow! such an awesome instructable!
14 years ago on Introduction
What a great idea! This would make a great gift!
14 years ago on Step 5
This is great! I'm planning on making one of me hiding in or behind different toys and things that belong to my daughter to encourage her to call me mama.
That was way cool! I'll definitely have to make some of these to add to all the other great toddler books I've got! I'm probably not going to be as successful as the ones outlined here, but it looks like a fun project to do with the kids.
This is simply fabulous! I love Photoshop and also my new nephew, Max. Now I have an awesome way to bring the two loves together. By the time I complete this project, Max will be just at the right age for his very own first book. Thanks for the wonderfully concise instructions!
Reply 14 years ago on Introduction
Thanks for the compliment, I hope you will share a few pictures of your project when your book is completed. :)
Love it!!!! There are blank board books for sale on internet. I got some on a reading instruction website. Probably couldn't/shouldn't mention website name if I remembered it or looked it up. Set came with sticker sheets the size of the books to print pages - then stick them on. I added a mirror to one page with same idea as the cutout of the flaps -- putting a mirror in the cutout part. I'd post it, but gave the book away. Be sure to get UNBREAKABLE mirror. I got metal one at science supply store. Since it's framed out, plastic would likely be ok too (toxicity not a problem, kid will chew edges of book not the mirror itself). Speaking of toxicity, folks- consider using white glue and other less-toxic stuff. The really great graphics spray adhesive has GOT to be bad for little people who will chew on the books.
Ok, I am marking this as a project for Christmas. Great instructable
nice and cool
15 years ago on Step 1
This si so beautifully done! What a wonderful idea. I know my girls would love this, especially my 1 yr old who is beginning to really explore books. Thank you for this instructable!
15 years ago on Introduction
Nice. I'd been meaning to do something like this but never got around to it. As far as how to make a board book from scratch, have a look at this:
http://degroof.home.mindspring.com/boardbook/boardbook.html
One of these days, I'll get around to making that into an Instructable.
15 years ago on Step 5
That was an awesome instructable. Great Job! Now I want to go out a purchase photoshop.
Reply 15 years ago on Introduction
Thanks! Unless you are a professional graphic designer I would recommend just buying Photoshop Elements. I'm still using version 2.0 and It's met my needs as an amateur photographer very well.
Just use GIMP - its free and easy
Try Paint.NET. One review says, "It's the free equivalent of Photoshop!"
Beautiful! I have done this on scrapbooks, but will have to make one of these as a card for a friend's birthday. Maybe a title of "Oh Where Have the Years Gone?".
