Introduction: Make a King Tut/Pharaoh Head Piece From an Old Hat
I could not find an acceptable King Tut or Pharaoh head piece for a costume. (Google them, they are terrible!) I got the idea how to make this when I wrapped my wet hair in a towel. This is how I made it:
Step 1: Supplies
Striped Material
Old Cap
Ruler
Chalk
Scissors
Pins
Thread
Cardstock or Cardboard
Your Knee
Step 2: Find a Picture
Find a picture online of a head piece of a pharaoh or King Tut.
Step 3: Buy Some Striped Fabric
Buy some striped fabric maybe about a yard and a half.
Step 4: Get an Old Cap
Get an old cap. (One you can cut up.) Use scissors and cut off the bill.
Step 5: Measure Fabric
Take your fabric and fold the end under about 5 inches. Make sure the stripes are running up and down.
Step 6: Put Cap on Your Knee
Now here’s where your knee comes in. Put the cap on your knee as if it was someone’s head.
Step 7: Lay That Folded Part on the Hat
Now take the material and lay that folded part on the hat. Make sure the stripes are vertical.
Step 8: Pin It to Hat
Bring the material down to the edge of the front of the hat and tuck it under an inch or so. Take your pins and pin this to the front part of the hat.
Step 9: Tuck in Sides
Put it back on your knee, now tuck in the sides as shown. The stripes on the sides hanging down will be horizontal, while the stripes on the forehead part will be vertical.
Step 10: Pin and Measure
Pin the sides to the hat. Take your ruler and measure how long the sides are. You might want to try it on a person to see where the sides hang on the persons shoulders.
Step 11: Draw Shape
Look at the picture you have. See how the sides are shaped? Draw that shape onto the cardboard and cut it out. (These will be inside the sides to hold its shape.)
Step 12: Align Cardboard
Align the straight edge of the cardboard with the fold on the side. Remember you had turned under 5 inches, so the part under the cardboard is actually a double layer 5 inches wide. Pin the cardboard to the side of the material. Take your scissors and cut out a space where the shoulder will go. Remember to leave half an inch around this cut out so you have a little seam allowance when you sew it. Do this on the other side too.
Step 13: Unpin
Now unpin the fabric from the hat, and lay it inside out flat on the floor, and refold as shown. (It’s hard to tell, but this is inside out.)
Step 14: Make Pocket
You will be make the pocket for the cardboard sides to slip into. Pin the sides together.
Step 15: Sew Pocket
Sew up the sides for the pocket for the cardboard.
Step 16: Turn Right Side Out
Turn the sides right side out. Slip the cardboard into the packets, (you may not need to.)
Turn in the raw edges around the shoulder holes, pin and sew.
Step 17: Repin
Now repin it back to the cap.
Step 18: Sew
Stitch the front of the fabric to the front of the cap.
Step 19: Try on and Check Sides.
Put the cap back on your knee. See how the sides hang.
Step 20: Check Length
Have someone try it on. Check the length.
Step 21: Trim
Trim the back to the right length.
Step 22: Hem
Fold under all raw edges, pin, and hem.
Step 23: You Are Done!
And there you have your King Tut/Pharaoh head piece for your costume!
Before and After Contest 2017
